Upper rad hose #879937 04/09/08 04:54 PM
salvo Offline OP
Did a swap last year and put a 88 3 core rad in my 85 22re pickup. The rad fits great but only problem i have is the upper rad hose neck has a 45% bend to the outside of the veh making the stock hose have a pretty tight bend to it. What hose have people used to correct this?
Re: Upper rad hose [Re: salvo] #879938 04/10/08 12:41 AM
xrtim Offline
B <img src="/forums/images/graemlins/pfft.gif" alt="" />end a coat hanger in the shape that you'd need the hose to be. Imagine the wire is running down the center of the hose. Then go to an auto parts store and look for a close match. Remember you can trim the ends, you'll be looking for a hose with the correct bends. Shouldn't be too hard.
Re: Upper rad hose [Re: xrtim] #879939 04/11/08 03:33 PM
salvo Offline OP
just spend a hour at te autoparts store pulling hoses off the wall and trying them... going to go to the local industrial place and get a big chunk of hose
Re: Upper rad hose [Re: salvo] #879940 04/11/08 04:44 PM
4Crawler Offline
What is the radiator off of? What sort of hose shape did it have?
I have a 3-row radiator in my '85 and it has a straight top hose fitting:
Maybe have a radiator shop cut off the old fitting and solder/braze on a straight one?
Re: Upper rad hose [Re: 4Crawler] #879941 04/13/08 01:47 AM
salvo Offline OP
ya i think thats what m going to have to do it get a strait one put on it ....
Re: Upper rad hose [Re: salvo] #879942 04/13/08 06:37 AM
Vanishing_Point Offline
Careful not to melt the other soldered joints.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6086 MB (Peak: 0.6787 MB) Data Comp: Off Server Time: 2026-07-13 18:31:18 UTC
