3.0 V-6 engine #880063 04/10/08 05:54 PM
RaiderRascal17 Offline OP
does anyone in the denver area have an extra 3.0 V-6 engine laying around?
Re: 3.0 V-6 engine [Re: RaiderRascal17] #880064 04/10/08 06:13 PM
I
ipdesign Offline
if no one has a spare one, just thought it will help:
http://denver.craigslist.org/search...k=min&maxAsk=max&addTwo=
i think if you find an old dodge caravan near you you can probably get it for under 1K, back a while ago i managed to find two for $100, one was not a v6 though. and they had the 3L mitsubishi in them. just do more searches.
1989 Dodge Raider SWB, V6, Auto, over 400000KM(not sure if true).
2004 Subaru Impreza Outback, 2.5Boxer, Manual.
1994 Dodge Caravan, V6(Mitsu), Auto 3spd.
and a lifetime away:
1993 VW Passat VR6, auto.
1985 Honda Magna V45(750CC)
Re: 3.0 V-6 engine [Re: ipdesign] #880065 04/10/08 06:22 PM
93montero_sr Offline
Assuming the 3.0 is for a montero/mighty max would it even be the same, being that its out of a front wheel drive van. I think everything else is a match like the heads,cams,coil,cap & rotor, spark plugs,plug wires. But i dont think that motor would work but i could be wrong.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: 3.0 V-6 engine [Re: RaiderRascal17] #880066 04/10/08 09:04 PM
If you cant find one locally check out www.msrecycling.com or www.car-part.com
car-part is a repository of salvage yard inventories around the US including Colorado, Utah, etc.
PHP: 7.4.33 Page Time: 8.318s Queries: 15 (0.005s) Memory: 0.6035 MB (Peak: 0.6597 MB) Data Comp: Off Server Time: 2026-10-24 03:18:51 UTC
