1990 22r problems #880070 04/10/08 10:00 PM
G
Greg_Canada Offline OP
It wont pass emissions, we've narrowed it down to a few things... the HC is high... what would cause that? Clogged cat?
Also, is there an o2 sensor/emissions computer in the 90' 22r's? (or is there supposed to be?)
89 4Runner
Re: 1990 22r problems [Re: Greg_Canada] #880071 04/11/08 04:46 AM
Davepet Offline
My Calif. 84 22r had a computer & an O2 sensor, so I'd expect a 90 to have them too.
Re: 1990 22r problems [Re: Greg_Canada] #880072 04/11/08 04:58 AM
OOP'S Offline
Yes it is in the PS kick panel, will not run without it. <img src="/forums/images/graemlins/smile.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 1990 22r problems [Re: Greg_Canada] #880073 04/11/08 05:01 AM
kewlynx Offline
Greg, to clarify, is that thing carbed or EFI? Last carb in the US was '87. (term 22R v. 22RE)
You can run the VIN thru carfax and see what they have in the database for it originally, if it's in there.
High HC for carb typically is the AAP or the cat. If your dipstick smells like fuel, make sure you change your oil and filter before going back in once you fix things.
**ubi apis- ibi salus**
Re: 1990 22r problems [Re: kewlynx] #880074 04/11/08 05:45 AM
87Toy4x4 Offline
Carbies were available until 1991 in the non sr5 2wd trucks.
Re: 1990 22r problems [Re: Greg_Canada] #880075 04/11/08 08:11 AM
Snowtoy Offline
High HC's is caused by an incomplete fuel burn or from running rich. What are the numbers? A new cat can knock the HC's down abut 100 or so and would be the cheapest place to start when you start replacing items. A failing/lazy O2 sensor will also cause it to run rich. You should also pull and check the EGR valve and PCV valves either if those get clogged it can also cause rich conditions. If you do have a 22re and not 22r an air leak in the intake after the AFM will also cause it to run rich.
Re: 1990 22r problems [Re: Snowtoy] #880076 04/11/08 02:10 PM
G
It's a 22r.... carbie, we bumped the timing up a bit and the truck ran alot better. havent done the e-test since doing that. Can timing effect HC?
Also, there is no o2 sensor, there is a pipe welded in place of where the o2 sensor is in a normal truck, still havent found the wiring for it.....
oh also a full tuneup was just done on the truck...
I will get some more info later in the day, it's a friends truck...
89 4Runner
Re: 1990 22r problems [Re: Greg_Canada] #880077 04/11/08 09:11 PM
Snowtoy Offline
Is it a factory weld over the O2 bung, or is it a private job. If factory does Canada emissions require an O2 on your carb'd '90?
Since it is carb'd, there is an air injection valve(at least on the older ones), that adds air to the exhaust gasses to help burn the unburnt fuel. If this is bad you will also get higher HC's than normal, which a new cat will not fix.
Timing can effect fuel burn and cause higher HC's, though I am not sure how much.
Did it fail at both idle and 2500 or dyno tests?
Re: 1990 22r problems [Re: Snowtoy] #880078 04/12/08 10:55 PM
A
absoface78 Offline
Just for reference, I have an "84 4Runner with a booger weld over the O2 sensor mount, but I found the single wire wrapped up on the driver's side inner fender near the coil. Wasn't easy to find among the thousands of crappy innovations the previous owner did.
Re: 1990 22r problems [Re: Greg_Canada] #880079 04/14/08 08:32 PM
P
Pyroboy Offline
Mine failed on high HC on idle last year. Dealer told me I needed a new cat but a set of plugs and wires and some ethanol-blend gas did the trick. If you can't get the gas, dump a bunch of gas-line anti-freeze in.
1989 4Runner Special Edition
22RE, 5-spd.
TG 3" SAS, MC DuaLs, 4.56s, Air Locker
Hi-Clearance panels by
www.toyotafiberglass.com
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6390 MB (Peak: 0.7630 MB) Data Comp: Off Server Time: 2026-06-07 07:23:02 UTC
