2002 Sportage - Fan Clutch #880414 04/11/08 11:04 PM
Kia_Bill Offline OP
Hello again!
I'm in need of assistance for a fan clutch replacement. After the $400+ dealer and local shop quotes, I figure this can't be all that hard, right? I hope.
Any helpful tips, steps, special tools I might need?
Thanks!!!
2002 Kia Sportage 4x4, stock.
Yes, I'm boring. I'm looking to change that.
Re: 2002 Sportage - Fan Clutch [Re: Kia_Bill] #880415 04/12/08 05:31 AM
bombardj1 Offline
www.kiatechinfo.com or some of the guys here put in eletric fan they could give insight to that, can order a clutch for the fan with out blade from autozone
Re: 2002 Sportage - Fan Clutch [Re: bombardj1] #880416 04/12/08 02:41 PM
Chris_Eichman Offline
I still have my clutch and fan from when I switched over to an electric fan. If you are interested pm me. I really recommend putting on an electric fan though. I saw about 10% improvement in gas mileage when I switched.
Re: 2002 Sportage - Fan Clutch [Re: Kia_Bill] #880417 04/12/08 04:33 PM
Dave Scott Offline
be very carefull with the nuts, they round off super-easy.
Re: 2002 Sportage - Fan Clutch [Re: Dave Scott] #880418 04/12/08 07:04 PM
Nukeiridium Offline
6 point socket FTW <img src="/forums/images/graemlins/smile.gif" alt="" />
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: 2002 Sportage - Fan Clutch [Re: Kia_Bill] #880419 04/14/08 03:39 PM
Kia_Bill Offline OP
Hey,that's perfect. Found the directions and even the part super cheap. Friggin mark ups.
I thought about the electric fan kit but it didn't look like a clean install and that part had me worried. I need it to run without remembering to switch it on and stuff and not run after the car is off.
Re: 2002 Sportage - Fan Clutch [Re: Kia_Bill] #880420 04/15/08 02:40 AM
Everet Offline
Just put in a relay that is fed by a "hot with key on" so that it won't run when key is off. Actually, it is only a 2 cocktail job. I will be changing to a SPAL FAN-PWM when I get the 3-row radiator made and installed.
Everet
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6149 MB (Peak: 0.6889 MB) Data Comp: Off Server Time: 2026-07-11 00:21:28 UTC
