Trans leak on right side from round port or something... #880442 04/12/08 02:49 AM
2
2002trooper4me Offline OP
So my trans started to slip today in first-second shift. I was near a trans shop I have dealt with in the past and he got me in. The tech comes to me and says I need to replace this round valve/port/thing on the right side of the trans that is leaking and I'm looking at 2hrs labor and a $25 part.
I know next to nothing about these Trans. I rebuilt my old C-6 years ago, but that is a super-simple 3 spd. These are a different thing all together.
So does this sound resonable or am I getting hosed? What the heck does this thing do anyway?
Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
"If you think you hate it now, just wait till you drive it!"
Mike M.
Richmond, Va
2002 Trooper, stock for now...
2002 Taurus Wagon "The Family Truckster"
Re: Trans leak on right side from round port or something... [Re: 2002trooper4me] #880443 04/13/08 05:18 AM
barak Offline
I had the same thing on my 4L30E , and its not a 2 hour job , my mechanic fixed it in about 30 minutes , all he replaced was a seal under it.
is yours metal or rubber for that round piece? Mine was metal so not sure if that makes a big difference or not.
Re: Trans leak on right side from round port or something... [Re: barak] #880444 04/14/08 02:56 AM
2
I thought he said it was ceramic, but maybe he was talking about something else. I thought 2 hrs sounded long to drop a driveshaft and pull a snapring.
You learn something everyday!
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Mike M.
Richmond, Va
Re: Trans leak on right side from round port or something... [Re: 2002trooper4me] #880445 04/21/08 03:48 AM
JLEMOND Offline
THAT IS THE SERVO PISTON COVER THAT IS LEAKING, ABOUT 12.00 FOR THE PT. AND AT THE MOST 1 HR LABOR , THE BACK END OF THE DRIVE SHAFT DOES HAVE TO BE MOVED , AND THEN THE PISTON IS REPLACED . NO BIG DEAL. JERRY
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6038 MB (Peak: 0.6595 MB) Data Comp: Off Server Time: 2026-06-07 04:41:52 UTC
