Center Console replacement #880541 04/13/08 06:27 AM
tlc_utah Offline OP
I wanted to check if I can replace the center console for my 1997 4Runner with the one from a 2000 4Runner.
Any comments are much appreciated.
1997 Toyota 4Runner SR5 4X4 with 230K + miles and going for 300K....
Everything is stock except K&N Air Filter and replaced CD changer with SCION MP3 player
Re: Center Console replacement [Re: tlc_utah] #880542 04/13/08 08:04 AM
G
Greg_Canada Offline
It should be a bolt in swap. You're going to need everything including the shifter boot. It'll be nice to have the cupholders (any console from 99-02 should be the same)
89 4Runner
Re: Center Console replacement [Re: tlc_utah] #880543 04/13/08 02:03 PM
P
pat161 Offline
The swap has been done before, but its not quite as easy as unbolting the old one and bolting the new one in. First the ebrake handles are a little different, your 97 comes straight out while the 99+ are angled slightly to the right. Second they moved the rear window switch to the dash in 99, yours is on the center console, so you will either need to build the switch somewhere in the new console or put it somewhere else.
Re: Center Console replacement [Re: pat161] #880544 04/14/08 04:48 PM
tlc_utah Offline OP
Thanks for the replies.
Are there any notes/sticky on how to do the changes?
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6006 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-11-03 13:38:21 UTC
