Re: clicking while turning?
[Re: Chunky]
#880739
04/15/08 10:51 PM
See if you can replicate the noise with the front end in the air. If so, poke around the hub while spinning the front wheel.
[Re: Chunky]
#880740
04/16/08 05:52 AM
On a side note, I do get a single clunk once in a while when turning and compressing the wheels at the same time. It was explained to me as a bad "half-shaft", I didn't really trust the guy. It still makes the noise occasionally I never heard of "half-shaft" before so I left it alone.
On this link on page SA-46 is what some people call a "half-shaft. Toyota calls them a "Front Drive Shaft". It is the front axles that go from the diff to each wheel. They have a CV type joint on each side and if you wheel IFS you should carry one or two. They are the same for both the PS and DS. They are the weakest link in an IFS front end. http://personal.utulsa.edu/~nathan-buchanan/93fsm/suspensionandaxle/18frontdri.pdf
"Serenity through Sobriety"
[Re: OOP'S]
#880741
04/18/08 02:50 AM
Good call Chunky that was exactly what it was snapped those little cover back to the inner fender well and it stopped makeing the noise.
Thanks for all the help everyone, Brian
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6010 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-07-15 07:11:51 UTCValid HTML 5 and Valid CSS
