Rod bolt failure #880798 04/14/08 05:51 AM
trashcanman Offline OP
I rebuilt my 22re from the ground up and the only thing I regret not taking the time to replace was the rod bolts. should I be worried or is it a rare accurance that one fails?
Re: Rod bolt failure [Re: trashcanman] #880799 04/14/08 03:24 PM
toyomorph Offline
the bolts holding the rod bearing caps on.... I sure wouldn't worry about them. As long as they were torqued to spec they should be fine.
canyon country explorer
1993 4x PUP
Re: Rod bolt failure [Re: toyomorph] #880800 04/14/08 05:19 PM
Staceman Offline
Clean and re-use.
I did 10K miles ago on my rebuild. (46 Ft/Lb's), no issues thus far.
Re: Rod bolt failure [Re: Staceman] #880801 04/14/08 05:23 PM
Vanishing_Point Offline
I know of several rebuilts with reused rod bolts and no problems. Unless they were subjected to high forces, (overtightening included), they should be fine.
Re: Rod bolt failure [Re: trashcanman] #880802 04/14/08 09:28 PM
engnbldr Offline
>>>*I would guess I have had a few hundred of those, maybe more in my hands.
We look them over, reuse them and if they pull to specs they are fine.
Failure rate is zero to date. *Not to worry....*EB
*Beats the he** outa me!....*LOL**...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6053 MB (Peak: 0.6696 MB) Data Comp: Off Server Time: 2026-05-29 23:51:51 UTC
