1987 Raider Coil Question #880959 04/14/08 11:04 PM
Raider Offline OP
Could someone please post a diagram or picture for the proper wiring of a coil for a 2.6 Raider? Thanks in advance. This will be a huge help.
Tommy
Re: 1987 Raider Coil Question [Re: Raider] #880960 04/14/08 11:45 PM
Note white ceramic resistor on side of coil.
To coil (-) terminal:
Blue wire from dist.
White/blue/black stripe to tach.
one other wire of unknown color goes to ecu (should go to same wire wrap as wires to carb).
To one end of resistor:
fat Black/red stripe wire from ignition start position
Short unknown color jumper wire to coil (+)
To other end of ceramic resistor:
Fat black/white stripe wire from ignition switch run position
smaller black white wire to distributor igniter (in same wire wrap as the blue wire to coil (-)
Re: 1987 Raider Coil Question [Re: fasteddy] #880961 04/15/08 12:35 AM
Raider Offline OP
Thanks FastEddy!!! Much appreciated!
Re: 1987 Raider Coil Question [Re: Raider] #880962 04/15/08 02:45 AM
Raider Offline OP
Fasteddy--thanks again. I have one more blue wire going to a resistor on the wheel well. I believe it goes to the positive on the coil but wanted to make sure. Thanks.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6016 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-06-20 21:40:14 UTC
