1987 Raider Coil Question
#880959
04/14/08 11:04 PM
Could someone please post a diagram or picture for the proper wiring of a coil for a 2.6 Raider? Thanks in advance. This will be a huge help.
Tommy
Re: 1987 Raider Coil Question
[Re: Raider]
#880960
04/14/08 11:45 PM
Note white ceramic resistor on side of coil.
To coil (-) terminal: Blue wire from dist. White/blue/black stripe to tach. one other wire of unknown color goes to ecu (should go to same wire wrap as wires to carb).
To one end of resistor:
fat Black/red stripe wire from ignition start position Short unknown color jumper wire to coil (+)
To other end of ceramic resistor:
Fat black/white stripe wire from ignition switch run position smaller black white wire to distributor igniter (in same wire wrap as the blue wire to coil (-)
[Re: fasteddy]
#880961
04/15/08 12:35 AM
Thanks FastEddy!!! Much appreciated!
[Re: Raider]
#880962
04/15/08 02:45 AM
Fasteddy--thanks again. I have one more blue wire going to a resistor on the wheel well. I believe it goes to the positive on the coil but wanted to make sure. Thanks.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6007 MB (Peak: 0.6559 MB) Data Comp: Off Server Time: 2026-06-20 21:44:04 UTCValid HTML 5 and Valid CSS
