2wd lift #880981 04/15/08 02:47 AM
mudz Offline OP
I know that i should probably buy a 4x4 sportage but right now that is out of the question due to time and money.
but regarding my kia does anyone know how i should go about lifting my 2wd sporty, i heard that tj springs will work in the back.
should i just go with spring spacers, or do spring spacers only work for 4wd vehicles.
please help me out.
even a 2wds vehicle with large enough tires can do some minor, minor off-roading.
Re: 2wd lift [Re: mudz] #880982 04/15/08 03:27 AM
mudz Offline OP
anybody got any kinda clue, i need some help desperately
Re: 2wd lift [Re: mudz] #880983 04/15/08 03:56 AM
Iron Offline
2" upyourkia spacers front and rear, or 2" spacers front with TJ spring rear or a 4" lift from RGS.
The only way to get the lowest point of the Sporty (Diff pumpkin) off the ground is with bigger tyres, the suspension lifts and body lift aid in clearance, but you can fit 30's with no (little) rubbing, on stock rims and stock height. lifting without adding larger tyres dosn't help the ground clearance.
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: 2wd lift [Re: Iron] #880984 04/15/08 03:58 AM
mudz Offline OP
thanks that really helps, but im assuming that the tj springs in the rear add 2 inches
Re: 2wd lift [Re: mudz] #880985 04/15/08 04:01 AM
Iron Offline
closer to 3-3 1/2"
08' Jeep Wrangler
58' Triumph TR-3A
Re: 2wd lift [Re: Iron] #880986 04/15/08 05:08 AM
mudz Offline OP
and i heard the 2 inch spacers from upyourkia add about that much correct
Re: 2wd lift [Re: mudz] #880987 04/15/08 06:12 AM
Everet Offline
3+ inches on 2" upyourkia spacers.
Everet
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6125 MB (Peak: 0.6855 MB) Data Comp: Off Server Time: 2026-07-10 01:33:41 UTC
