upper control arm bushings #880989 04/15/08 04:40 AM
johnu Offline OP
I need to replace the right front upper control arm bushings on my 98 trooper. Anyone done this? If so any tips or advice on the job.
Re: upper control arm bushings [Re: johnu] #880990 04/15/08 12:42 PM
HCMP Offline
I've done it. Its not aweful. I had to have the bushings pressed off. No amount of banging, torching and prying would do it.
You've got to open the brake system so get ready to bleed them. yey.
Take pictures, notes and draw diagrams of where your spacers are when you take that upper control arm off. If you don't put them back in the same exact way your alignment will be off. The "bar" that the bushings are pressed onto and that the UCA bolts pass through also need to stay in it's proper orientation. front, back, inboard, outboard.
Hopefully you've got less rust than my New England Amigo does. Have fun, good luck. Its not too bad a job.
--jeremy
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5899 MB (Peak: 0.6378 MB) Data Comp: Off Server Time: 2026-05-29 22:16:22 UTC
