Where to purchase/install tranny temp gauge for '90 4runner (auto)? #881045 04/15/08 05:24 PM
Q
qdude79 Offline OP
Want to be able to monitor this beast. Summit doesn't have 'em...
If I had to rig my own, where's the best place for the sending unit?
Thanks
"The only true wisdom consists in knowing that you know nothing."
Re: Where to purchase/install tranny temp gauge for '90 4runner (auto)? [Re: qdude79] #881046 04/15/08 06:49 PM
Bustedback Offline
I picked one up from NAPA for my boss's truck. I just installed the sender into one of the pressure test ports that was plugged with a 1/4 plug. You can drill a hole in the pan for the sender, but you just might cause a leak if it is not sealed good. I installed the kit on a Chevy with a turbo 350, but I'm sure there would be a pressure test port on a Toyota auto that you could tap into.
Re: Where to purchase/install tranny temp gauge for '90 4runner (auto)? [Re: Bustedback] #881047 04/16/08 04:26 PM
Q
qdude79 Offline OP
Not familiar with this auto tranny. Where would the test port be?
Re: Where to purchase/install tranny temp gauge for '90 4runner (auto)? [Re: qdude79] #881048 04/20/08 04:03 AM
turtlejim Offline
Use a automotive water temp gauge. Get fittings from a hardware store or an auto supply store. Make a "T" in the a/t line that sends hot atf to the radiator and plumb the sender into the hot a/t line.
Re: Where to purchase/install tranny temp gauge for '90 4runner (auto)? [Re: qdude79] #881049 04/20/08 09:53 AM
ldivinag Offline
there are 2 lines coming from tranny to the front where a small radiator resides.
the 2 lines just attach with hose clamp.
you can insert a small probe in there with not much hassles. remember, one is hot, with the fluid coming FROM the tranny and the other tube is a cooled out side...
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: Where to purchase/install tranny temp gauge for '90 4runner (auto)? [Re: ldivinag] #881050 04/20/08 03:38 PM
OOP'S Offline
Here is a place that has them;
http://www.egauges.com/
The best spot is the out line from the tranny to the the cooler. That is where it is the hottest.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6086 MB (Peak: 0.6778 MB) Data Comp: Off Server Time: 2026-05-29 15:33:33 UTC
