Starting problem
#881051
04/15/08 06:40 PM
Hey E1,
This morning my girl hesitated about 1 second before starting. Has never done this before. I have a good battery. What could be the problem? Starter going, wires loose I checked under the hood and all wires look fine no corrosion. Any thoughts would be helpful.
If it is the starter how hard are they to replace?
Thanks for helping the Mechanically Challenged. <img src="/forums/images/graemlins/confused.gif" alt="" />
Drew
91 Monty RS stock sitting on 31's w/polished Alum 16"s 265,000 orig.
Re: Starting problem
[Re: Drewz]
#881052
04/15/08 07:49 PM
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
[Re: Drewz]
#881053
04/15/08 09:01 PM
Define hesitated please. For instance, did it do absolutely nothing, or did it not engage the starter, or did it turn over longer than normal before lighting off?
[Re: 93montero_sr]
#881054
04/15/08 09:03 PM
Did the starter hesitate to crank after you turned the key or did the engine hesitate to start after cranking? If the starter is hesitating & all your battery cable & starter connections are clean & tight, then I'd suspect your ignition switch. I regularly get a hesitation or nothing at all the first time I turn the key but it always cranks strong after that. It's been doing that for years now & has never become any worse or not started for me.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#881055
04/15/08 10:14 PM
it would be more like a dragging then nothing. It starts to engauge then hesitates then cranks over strong.
[Re: Drewz]
#881056
04/15/08 10:20 PM
Yep its draging take it off and have it tested.
