Can I rip out my air Pump? #881216 04/16/08 06:03 AM
L
lostcause Offline OP
I was looking at my v6 in my '91. I noticed I have an Air pump....i don't know what this is doing here? So I looked in my haynes (useless) manual, (anyone know if a bently is available for this truck?) and looked at the whole air pump system and saw that it is essentially taking air from my TBI and putting it straight into my Exhaust?
So I say: "Steal air from my engine will you? I'll rip you out you useless peice of junk." <img src="/forums/images/graemlins/angry.gif" alt="" /> Then I says to myself: "Self, be rational. Ask the guys on Isuzu forum. They'll know."
So here I ask. Does anyone really know what the air pump does other than steal air from my TBI? v6 in 91 trooper.
Cheers <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Can I rip out my air Pump? [Re: lostcause] #881217 04/16/08 06:35 AM
mlclark Offline
Isuzu Moderator
Well...it allows your catalytic converter to work correctly.
And...it is illegal to remove it, regardless if you have emissions testing in your area or not.
So...because that is one of the few "rules" we have around here (discussing illegal activities) this discussion should be considered done.
I will say, it does not "steal" air from your engine and in the end, it does not really take much "power" to run as it usually only operates during start up and at WOT.
Good Luck,
Michael
Re: Can I rip out my air Pump? [Re: lostcause] #881218 04/17/08 12:25 AM
Gizzy42 Offline
I disconnected the one on my '84 pup when I had it. Would hook it back up for emissions inspections. There was very little gain in disconnecting it. Since I live at 5500 ft elevation and frequently go over 12k ft passes in the mountains every tiny bit helps (especially with that very under powered 4 cyl). But if you dont live at high elevation I doubt you would notice any difference in power so no point in messing with it.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: Can I rip out my air Pump? [Re: Gizzy42] #881219 04/17/08 05:52 AM
L
Well thanks. Sorry about the illegal thing. Didn't know.
Feel free to delete this post then at any time Micheal if it runs contrary to the guidlines.
Thanks for the info all the same.
Re: Can I rip out my air Pump? [Re: mlclark] #881220 04/17/08 11:22 AM
strawmyers Offline
Isuzu Moderator
Sean Strawmyer
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6080 MB (Peak: 0.6732 MB) Data Comp: Off Server Time: 2026-06-07 04:51:10 UTC
