tire size question #881275 04/16/08 05:37 PM
sportagebandit Offline OP
i am looking at a set of super swamper ltb 34 x 10.50 r 15. has anyone ran any thing bigger than a 31 tire on there sportage. i think tey might rub on the rear of the front wheel well. but how bad would they rub...34" tire is really 33.5"
dave , didnt you run 32" tires before sas.
i could have sworn there was someone else running 35" tires.
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: tire size question [Re: sportagebandit] #881276 04/16/08 05:48 PM
Everet Offline
I know that with a 1.4 body lift, upyourkia 2" front spacers (that give about 3" of lift), and TJ rear springs, that 31 10.50's rubbed pretty good until the bottom part & seam of the front fender by the door was smashed back. It didn't hit anything on the front side because the front bumper was removed.
Let us know what you find out.
Re: tire size question [Re: Everet] #881277 04/16/08 10:10 PM
DamKia Offline
Kia Moderator
No matter how much and in what way you lift, anything over about 31.5" REAL diameter (not manufacturers make believe diameters) WILL foul on the firewall body mount on the chassis under any sort of suspension compression. May be OK as a mall cruiser, but you will be ripping lugs off left, right, and center on the trails....May in fact be less than 31.5" depending on the tread/lug profile of the tire.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5934 MB (Peak: 0.6476 MB) Data Comp: Off Server Time: 2026-05-29 22:36:15 UTC
