Shifter boots and front axles #881308 04/16/08 08:48 PM
Jim_Welsh Offline OP
What would make a good replacement for the shifter boot on a 1987 Trooper? My Æ87 has the æroundÆ shifter boot. My previous Æ87 and my Æ91 Troopers had the æsquareÆ or ærectangularÆ shifter boot. The date of manufacture on my current Æ87 is January 1987.
Apparently, there were 2 different shift boots for the 1987 Trooper, and they are both on back order from Japan. My other question would be since the date of manufacture is January 1987; would this Trooper have the 17 spline front axles or the 24 spline front axles? I really donÆt want to remove the auto hubs until I know for sure. I have a brand new set of Superwinch hubs that I want to use, but they will not work if I have the 24 spline front axles. When did Isuzu switch from the 24 spline to the 17 spline front axles?
Thanks.
Re: Shifter boots and front axles [Re: Jim_Welsh] #881309 04/16/08 10:58 PM
mlclark Offline
Isuzu Moderator
I don't know about the boots, but I doubt you can get them new. I don't think they have been available for a long time. The junkyard is an option.
With a 01/97 date, I would put a good bit of money being yours has the 17-spline axles. I would also guess you have a rear 10-bolt axle with drum brakes. While the division is not that sharp, it tends to be the later build dates that started using the 88-up parts.
Good Luck,
Michael
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5876 MB (Peak: 0.6361 MB) Data Comp: Off Server Time: 2026-06-07 07:25:47 UTC
