Ford 2.3l in an 86 Montero #881446 04/17/08 04:45 PM
smittylite Offline OP
Newb here wondering if that would work......?? Local here has a 86 Montero for sale with a blown engine and I have a friend with a carbuerated Ford 2.3l out of an 80's Mustang. I was just wondering if it would be possible to mate the 2.3 to the KM145 transmission. If I remember correctly some of the Bronco II and Rangers had a Mitsu 5spd known as the FM145.
Re: Ford 2.3l in an 86 Montero [Re: smittylite] #881447 04/18/08 01:31 PM
toddstidham1 Offline
Different bell housing, so it wouldn't be a direct swap. More then likely, it's just blown the cyl. head gasket or cracked the head. The bottom ends on the 2.6L are pretty stout.
-Todd
1987 Montero 2.6l 5-speed (Sold...but I still miss her)
2008 Jeep Patriot Sport 4x4
Re: Ford 2.3l in an 86 Montero [Re: toddstidham1] #881448 04/18/08 02:18 PM
8
89Diesel Offline
toddstidham1-Are you sure about the bellhousing? I took a 2.3l diesel from an '86 Ranger and put in my 89 D50. Both 5 spds, the wrecker I got it from, told me another fellow swapped a "85 2.3 diesel into a '86 2.3 gasser Ranger. All kept orig. trannys.
Long way around it, but if you add it all up, it should fit. But, I've been wrong before...LOTS!
A day late, A dollar short, and A half a mile behind...
pass me that crescent hammer...
Re: Ford 2.3l in an 86 Montero [Re: 89Diesel] #881449 04/18/08 05:51 PM
Different bellhousings on the earlier Mitsus. Maybe up through 85 should bolt up.
Re: Ford 2.3l in an 86 Montero [Re: smittylite] #881450 04/19/08 02:29 AM
Yes the Broncos used a Mitsubishi Transmission that has a removable bell. Not sure which engines it was behind.
The diesel in the Ranger is a Mitsubishi engine so it should look like a Mitsubishi.
To install a Ford 2.3 in a Montero, used the trans from a Bronco. I am not sure what the output spline is on that trans as far as mating to the transfer case so it might take a bit of mix and match to get it all together.
Re: Ford 2.3l in an 86 Montero [Re: 89Diesel] #881451 04/19/08 08:05 PM
For a 2.3L gas engine, yes...different bell. The 2.3L Diesel engine is a mitsubishi engine and has the 2.6L bell housing.
-Todd
Re: Ford 2.3l in an 86 Montero [Re: smittylite] #881452 04/22/08 03:09 PM
JPF Offline
I just recently put a 2.5l (2.3 stroked) in a 86 montero. I used to race pro-4's here in OK and had one around. I work at a machine shop and could build what ever I needed. I had to build an adapter plate to match up the block & bell housing, the starter is on the wrong side. Tuff but can be done.
JPF
TULSA , OK
Re: Ford 2.3l in an 86 Montero [Re: JPF] #881453 04/22/08 03:36 PM
It would have been much easier to use the Ford bellhousing and transmission case that bolts into a Montero.
Re: Ford 2.3l in an 86 Montero [Re: OldColt] #881454 04/22/08 05:12 PM
thanks for the information. I may take a look at the Montero later this week and try to see exactly what is wrong with it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6262 MB (Peak: 0.7291 MB) Data Comp: Off Server Time: 2026-06-22 07:36:19 UTC
