1990 22r 14MPG?! #881455 04/17/08 04:55 PM
daveowen Offline OP
Hey guys - got all the starting and running bugs worked out.
I have changed -
-plugs
-wires
-cap + rotor
-coil
AAP is working - no leaks or holes in the diaphram. Starts good, runs good. Only getting 14mpg. Any ideas?!
Edit: Forgot to mention its a 2wd reg cab short box - 250 000 clicks, stock size tires.
Re: 1990 22r 14MPG?! [Re: daveowen] #881456 04/17/08 07:23 PM
Davepet Offline
Have you checked all the other diaphragms for leaks?
Run a compression check recently?
Re: 1990 22r 14MPG?! [Re: Davepet] #881457 04/18/08 12:27 AM
Billydkid Offline
I'd check the converter, and O2 sensor with that many miles.
93 4runner V6, 4.88's, 31" mt's with more to come.
03 Tundra V8 on 265's
Re: 1990 22r 14MPG?! [Re: daveowen] #881458 04/18/08 01:23 PM
MuddRunner Offline
You could also check your air flow meter, TPS and see if your throttle plate needs cleaning. I just had a problem with my AFM and replaced the O2 sensor. My mileage is back up to around 22+ daily driving.
'92 Pickup x-cab, 22re, auto.
'50 Ford Tudor Sedan, my new "Hot Rod"
Too much to do, too little time/$$$
Heb. 12.3
Re: 1990 22r 14MPG?! [Re: MuddRunner] #881459 04/18/08 03:29 PM
G
Greg_Canada Offline
It's a 22r.
89 4Runner
Re: 1990 22r 14MPG?! [Re: Greg_Canada] #881460 04/18/08 06:31 PM
daveowen Offline OP
guys, its a 22R , not an RE
Re: 1990 22r 14MPG?! [Re: daveowen] #881461 04/19/08 12:40 AM
Vanishing_Point Offline
Auto or 5 speed? If your clutch packs/bands slip or the lockup doesn't function in an auto, your mileage goes south.
Re: 1990 22r 14MPG?! [Re: Vanishing_Point] #881462 04/19/08 04:36 AM
daveowen Offline OP
5 speed - new clutch.
Re: 1990 22r 14MPG?! [Re: daveowen] #881463 04/19/08 11:46 AM
O
ovrrdrive Offline
Ouch... I was going to say that was about right until I saw you have a 2wd truck.
Even with a 22R I think you should be around 25 or so. Do you still have stock tires on it or did you upsize?
Re: 1990 22r 14MPG?! [Re: daveowen] #881464 04/19/08 03:34 PM
xrtim Offline
Are you having to drive it with your foot to the floor to get any performance? If so maybe your timing is off, or like me the vac lines going to the dist. cap were backwards and my timing was retarding instead of advancing. I switched them and all is right with the world. Give it a shot. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6330 MB (Peak: 0.7388 MB) Data Comp: Off Server Time: 2026-07-14 21:49:14 UTC
