1988 2.6 auto Trans question
#881551
04/18/08 05:11 PM
Still having problem with over drive. If I go on the freeway and drive 4-5 miles at 65mph and slow down over drive will start working until I turn the car off. If return to the car and start driving again no OD. My question is I know based on all the discussions on this topic the most logical problem is electrical but does OD also work off of line preasure or maybe because I am not using Mitsubishi ATF a valve is sticking? At $4 a gallon I hate not having over drive. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 1988 2.6 auto Trans question
[Re: bigroxydog]
#881552
04/18/08 08:33 PM
There's a coolant temp switch in the o/d relay coil ground path that won't let it go into o/d until it warms up. If your thermostat is bad (stuck open) or missing it will do what you describe. You can ground the wire at the sensor/switch, replace the t'stat, or replace the sensor/switch (on the water neck, one skinny wire connection. Other one wire sensor is for the gauge. Two wire sensor is for ecu.
[Re: bigroxydog]
#881553
04/18/08 08:35 PM
First place I would look...
There is a thermal switch on the intake manifold to turn off your overdrive if the engine overheats. Over time the connection on it loosens and it becomes intermitant.
Its a single wire sensor near the thermostat.
Kevin C
[Re: Kevin C]
#881554
04/18/08 09:23 PM
Thanks guys I will try your ideas this weekend.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6015 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-06-07 06:10:42 UTCValid HTML 5 and Valid CSS
