Page 1 of 3 1 2 3
Ball Joint replacement #881557 04/18/08 10:51 PM
MAC Offline OP
I knew my ball joints were a little sloppy (87 4runner) but when I checked them today ...holy moley, they seemed to have wore a lot since I last checked them. Anyways, I rember years back there was a great step by step procedure bouncing around. Anyone know where it is?
I need to do both uppers and lowers, can it be done without pulling the hubs, brakes, and the whole magilla? Thought I remember that you don't have to pull the whole darn thing apart...
Re: Ball Joint replacement [Re: MAC] #881558 04/19/08 01:28 AM
Snowtoy Offline
The '93 FSM at the top of the forum will work for your '87.
You don't need to remove the hubs, you can do one joint at a time, and not have to pull the entire wheel assembly off.
Re: Ball Joint replacement [Re: Snowtoy] #881559 04/19/08 11:49 AM
O
ovrrdrive Offline
It's a pretty easy job. Probably the only thing you'll even need the FSM for is the torque specs. Just do them one at a time and just replace what you see. Just have a pickle fork and a bfh handy and it will be pretty easy.
Re: Ball Joint replacement [Re: ovrrdrive] #881560 04/22/08 11:21 PM
mmcpeck Offline
Where is that FSM, I don't see it?
They don't need to be pressed in?
If you do one at a time, I assume the one opposite the one your replacing will hold everything together right?
Re: Ball Joint replacement [Re: mmcpeck] #881561 04/23/08 12:36 AM
OOP'S Offline
The top thread.
85, 93, et. al. Toy FSM's ~Reviewed 01/01/2008~
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Ball Joint replacement [Re: mmcpeck] #881562 04/23/08 09:24 AM
Snowtoy Offline
No they are bolted in, only 5 nuts to be removed.
Correct, though using a floor or bottle jack will be helpful to support the weight, once you disconnect the upper or lower ball-joint.
Re: Ball Joint replacement [Re: Snowtoy] #881563 04/23/08 04:58 PM
MAC Offline OP
Interesting... I ordered upper and lower joints from 1sttoyotaparts (87 4Runner) and they are all a different p/n's ... ie. upper LEFT is differernt p/n than upper RIGHT etc. Never saw this before.
Re: Ball Joint replacement [Re: MAC] #881564 04/24/08 09:39 PM
mmcpeck Offline
My driver side upper joint is bad, can I just replace that one or is usually better to do both upper and lower when you do them?
Re: Ball Joint replacement [Re: mmcpeck] #881565 04/25/08 01:40 AM
Snowtoy Offline
Chances are they are all bad/starting to fail, so It would be best to replace them all. However, if money is tight, you can just replace one at a time or one side at a time, if you wanted to spread the costs out over a few paychecks. Just remember that bad joints will cause poor alignment and tire wear, so you will want to fix them as soon as you can.
Re: Ball Joint replacement [Re: MAC] #881566 04/25/08 04:25 AM
P
PUGGY Offline
[color:"blue"] [/color] one at a time is the way togo...but when you do it the long way... you get a chance to check things out and grease/adjust up those wheel bearings, check/replace spindal bushings and check seals. fyi, enjoy. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6375 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-10-24 03:23:43 UTC
