Use Lucas Transmission Fix... or better not??? #881653 04/19/08 01:45 AM
Arnoud Offline OP
'91 LC (190k) ATF hose broke, I lost all ATF fluid. Fixed hose, bought new ATF. Guy in car shop sold me Lucas Transmission Fix - said it was good to use in older cars.
I'm not sure - like some opinions. Transmission was working without any problems, no slip, shifts beautifully.
I read it is good for preventive maintenance. But I also read it's very thick goo which may clog up the filter and/or do potential other damage.
All comments are very welcome - seems it was not discussed on this forum before. Thanks!
'91 LandCruiser
Re: Use Lucas Transmission Fix... or better not??? [Re: Arnoud] #881654 04/19/08 02:24 AM
MAC Offline
Nooooo. Don't put that gunk in there. oem spec ATF only. Why would you want to mess with it if it has no problems?
Re: Use Lucas Transmission Fix... or better not??? [Re: MAC] #881655 04/19/08 01:15 PM
gueroblanco Offline
dont use the tweaker motto: "if it aint broke, fix it til it is."
'95 runner 3vze/r150f
Re: Use Lucas Transmission Fix... or better not??? [Re: gueroblanco] #881656 04/19/08 01:27 PM
O
ovrrdrive Offline
I hate to sound like a broken record, but I used the Lucas engine treatment twice and both times I had to have a new motor put in about 3 months later...
Additives aren't necesarry...
Re: Use Lucas Transmission Fix... or better not??? [Re: Arnoud] #881657 04/20/08 03:16 AM
904runner2dr Offline
One more thing.Don't use that stuff,OEM fluid is perfect.
Re: Use Lucas Transmission Fix... or better not??? [Re: 904runner2dr] #881658 04/20/08 05:11 PM
salvo Offline
Used thr trans fix once 2 weeks later i had no forward gears left. One big boom at the stop light and done.... Trans ran perfect before i used it too...
Re: Use Lucas Transmission Fix... or better not??? [Re: 904runner2dr] #881659 04/20/08 05:17 PM
Arnoud Offline OP
Thanks for the responses! Yeah, don't fix if it ain't broke.
In some other car forums there are reports it "saved" them... but none here(?). I guess it helps (temporary?) if something is wrong with the transmission already.
I wonder what causes other (older) cars to suffer from transmission slip, bad shifting etc. I can see some wear on the gears, but that shouldn't cause slip, right?
'91 LandCruiser
Re: Use Lucas Transmission Fix... or better not??? [Re: Arnoud] #881660 04/20/08 07:18 PM
Arnoud Offline OP
The car shop guy also seems to have sold me the wrong ATF type (type F), while my (Haynes) manual lists Dexron II. Good I didn't put it in yet!
However, it seems Dexron II is no longer for sale, replaced by Dexron VI. But what about this:
Dexron-VI -- For 2006 GM Hydra-Matic 6L80 6-speed rear-wheel-drive transmissions, can also be used in 2005 transmissions that require Dexron III but is NOT recommended for older transmissions.
What actually is the correct (OEM) ATF to use (for a Toyota LC 1991)?
'91 LandCruiser
Re: Use Lucas Transmission Fix... or better not??? [Re: Arnoud] #881661 04/20/08 08:30 PM
W
walktastic Offline
what about the stuff in the silver can called engine restor? would that cause problems in the engine? i only ask since we are on the subject of additives.
V6 pickup 4x4, 385,000 miles and still ticking
Re: Use Lucas Transmission Fix... or better not??? [Re: Arnoud] #881662 04/20/08 09:43 PM
toyomorph Offline
You could probably use Red Line Synthetic ATF, or D4 ATF, in place of Dexron II.
Red Line D4 ATF
canyon country explorer
1993 4x PUP
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6354 MB (Peak: 0.7420 MB) Data Comp: Off Server Time: 2026-06-07 04:40:35 UTC
