Cooling bypass hose?
#881761
04/19/08 09:12 PM
My brother had the dealer do the timing belt on his 2000 Trooper with a 3.5 dohc 24 valve engine. On the bill the dealer claims to have replaced the Cooling bypass or Cooling crossover hose. Where is this hose located as we can not see a new hose anywhere under the hood. The dealer also is trying to charge for several other things my brother did not authorize. Thank you
Re: Cooling bypass hose?
[Re: mybrotherstrooper]
#881762
04/20/08 01:25 AM
I don't know that specific motor but on many engines there will be a small hose that has one end that attaches at the thermostat housing and runs to a water port on the intake manifold.
[Re: lttlbddy]
#881763
04/20/08 04:36 AM
I don't know that specific motor but on many engines there will be a small hose that has one end that attaches at the thermostat housing and runs to a water port on the intake manifold. I hope thats not it the dealer is trying to charge $180.00 to replace it.
#881764
04/21/08 05:49 PM
The reason it costs that much is you have to remove the entire intake manifold in order to get to it.
-john
99 Rodeo 3.2L 4WD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6032 MB (Peak: 0.6590 MB) Data Comp: Off Server Time: 2026-06-07 09:13:32 UTCValid HTML 5 and Valid CSS
