Cooling bypass hose? #881761 04/19/08 09:12 PM
mybrotherstrooper Offline OP
My brother had the dealer do the timing belt on his 2000 Trooper with a 3.5 dohc 24 valve engine. On the bill the dealer claims to have replaced the Cooling bypass or Cooling crossover hose. Where is this hose located as we can not see a new hose anywhere under the hood. The dealer also is trying to charge for several other things my brother did not authorize.
Thank you
Re: Cooling bypass hose? [Re: mybrotherstrooper] #881762 04/20/08 01:25 AM
lttlbddy Offline
I don't know that specific motor but on many engines there will be a small hose that has one end that attaches at the thermostat housing and runs to a water port on the intake manifold.
Re: Cooling bypass hose? [Re: lttlbddy] #881763 04/20/08 04:36 AM
I hope thats not it the dealer is trying to charge $180.00 to replace it.
Re: Cooling bypass hose? [Re: mybrotherstrooper] #881764 04/21/08 05:49 PM
slappy Offline
The reason it costs that much is you have to remove the entire intake manifold in order to get to it.
-john
99 Rodeo 3.2L 4WD
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6002 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-06-22 11:19:50 UTC
