Transmission/year compatibility questions 3.0 v6 #881765 04/19/08 09:15 PM
Sinkut_Laker Offline OP
Hi,
1994 model year 4Runner, 3.0 v6. Automatic Trans. is failing and I may replace it. Its code from doorjamb:
A/TM G144 / A340H
I have 2 transmissions to choose from:
1/ 1989 model year Ext Cab Pickup, 3.0 v6, Auto Trans. DoorJamb code:
A/TM G252 / A340H
2/ 1992 model year 4Runner, 3.0 v6, Manual Trans
DoorJamb code:
A/TM G284 / R150F
What are my options for swapping either of these transmissions into the 94 4Runner? I can find lots of information on the net about what the codes mean, but not much on bolt-in compatibility, etc.
thanks very much,
Scotty
Re: Transmission/year compatibility questions 3.0 v6 [Re: Sinkut_Laker] #881766 04/19/08 09:17 PM
Adam F Offline
Either will bolt up. The A340H will be a direct swap.
Of course, a lot more work to bolt in the R150 manual transmission in place of your A340H auto trans.
97 4R, stock, daily driver
Re: Transmission/year compatibility questions 3.0 v6 [Re: Sinkut_Laker] #881767 04/20/08 06:41 AM
Snowtoy Offline
The code w/starting w/G refers to the gears in the 3rd members, the A340H is for the automatic tranny. As mentioned the auto will be a direct bolt it, and should work from any 2nd gen Runner/pickup.
If you can drive a 5-spd or ever wanted to learn, the swap is doable, you just need the cluster master and slave cylinders, the petal and linkage, and I believe a manual transfercase, I don't think the auto will still work w/a manual transmission. It will take longer and probably cost a bit more, but you will get better performance and mpg's for your effort.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5927 MB (Peak: 0.6463 MB) Data Comp: Off Server Time: 2026-06-07 04:22:46 UTC
