4Runner wont start at all! #882143 04/22/08 04:37 AM
Johnboy Offline OP
Post Undeleted
854Runner, pretty much stock engine and fuel system.
I parked to have dinner one night and afterwards it wouldn't start. Nothing was out of the ordinary.
Here's what I know:
I have spark.
The fuel pump is not working.
Using the jumper does not turn the fuel pump on.
The AFM checked out OK.
The circuit opening relay good.
New Fuel Pump installed.
Where else do I look? I'm lost, please advise.
John
85 4Runner, 4" lift, bumpers, sliders, locker
Re: 4Runner wont start at all! [Re: Johnboy] #882144 04/22/08 04:49 AM
4Crawler Offline
Re: 4Runner wont start at all! [Re: 4Crawler] #882145 04/26/08 10:37 PM
Johnboy Offline OP
Test jumper didn't turn on the fuel pump... what else?
Re: 4Runner wont start at all! [Re: Johnboy] #882146 04/26/08 11:29 PM
Snowtoy Offline
Do you have power to the fuel pump when you turn the key on?
The new pump could be bad. I would drop the tank and pull the pump to make sure it is working.
Re: 4Runner wont start at all! [Re: Snowtoy] #882147 04/26/08 11:45 PM
Johnboy Offline OP
No power when I turn the key on. I checked and there is no voltage going to the pump. Old one wasn't bad and the new one seems to be fine too.
I checked power to the circuit opening relay and got less than 1 volt. Will this open the relay? Perhaps this is the problem. Next place to check is the main EFI relay.
Re: 4Runner wont start at all! [Re: Johnboy] #882148 04/27/08 12:39 AM
4Crawler Offline
A 12 volt relay typically needs 6-9 volts to operate the coil and make it pull in the contact(s).
Re: 4Runner wont start at all! [Re: 4Crawler] #882149 05/03/08 05:45 AM
datsun_73 Offline
Here is orders Iwould go:
1. Check battery (obviously it is ok if it cranks)
2. Check the fuel pressure by connecting a gauge to the fuel line nearby intake
3. Check plugs power by pulling a plug out and trying to short it to engine block. Power is there If you see the sparks Be very careful do not get yourself shocked
4. Timing belt will be next
Hope it helps. Good luck!
Re: 4Runner wont start at all! [Re: datsun_73] #882150 05/03/08 08:47 PM
Johnboy Offline OP
I have definitely established that there is no fuel pressure and no voltage to the fuel pump.
Here are what I believe to be two major indicators of problems:
1: There was a ground cable disconnected
2: The EFI fuse plastic casing was partially melted but the fuse was not blown. If a surge of electricity hit the EFI and the fuse didn't blow, what got trashed??
Re: 4Runner wont start at all! [Re: Johnboy] #882151 05/03/08 09:02 PM
4Crawler Offline
Unlikely you had a "power surge", probably what happened with the melted part was a high resistance connection (due to corrosion or oxidation) and that makes heat (watts = amps * amps * resistance). So check for bad/dirty/loose connections at the fuse, and at any wire connections between the power source and device.
Re: 4Runner wont start at all! [Re: 4Crawler] #882152 05/03/08 10:37 PM
Johnboy Offline OP
The schematic shows two fusible links between the EFI fuse and the battery. Any idea where those two are?
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6406 MB (Peak: 0.7640 MB) Data Comp: Off Server Time: 2026-07-15 02:38:33 UTC
