Re: 4Runner wont start at all! [Re: Johnboy] #882153 05/04/08 01:02 AM
4Crawler Offline
The schematic shows two fusible links between the EFI fuse and the battery. Any idea where those two are?
AM1 and AM2 location below:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Electrical
Re: 4Runner wont start at all! [Re: 4Crawler] #882154 05/04/08 06:35 PM
Johnboy Offline OP
AM1 and AM2 both show a good fuse and have ~0 resistance.
85 4Runner, 4" lift, bumpers, sliders, locker
Re: 4Runner wont start at all! [Re: Johnboy] #882155 05/04/08 10:08 PM
4Crawler Offline
To find where things go bad, start at the battery and measure voltages as you move along the circuit that supplies power to the device that is not working. Assuming no voltage at the device and good voltage at the battery, find some point in between and measure there. If voltage is good, then move towards the device and repeat, otherwise move towards the battery and repeat the test. The point of failure will lie between the point where the voltage is good and where it is bad. Keep dividing that segment of the circuit in parts until you find where the fault is.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6014 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-07-15 15:47:53 UTC
