BAD BEARING IN MY TRANNY! #882170 04/22/08 09:03 AM
trashcanman Offline OP
Anyone had your tranny rebuilt lately? theres a bad bearing in my tranny and its driving me nuts!about how much would it cost to have a mechanic pull it and rebuild it? would it be better just to buy one from marlin crawler? its a 92' five speed 4x4 22re
Re: BAD BEARING IN MY TRANNY! [Re: trashcanman] #882171 04/22/08 12:27 PM
toyomorph Offline
HI. Just curious, what does it sound like? I have a G52 in my 93 that makes a strange noise at low r's and on deceleration. Kind of a whirling, clicking sound.
canyon country explorer
1993 4x PUP
Re: BAD BEARING IN MY TRANNY! [Re: toyomorph] #882172 04/22/08 04:37 PM
mine sounds like dragging piece of metal on a slow turning grinding wheel. I dont think its the throw out bearing because it goes away when you put the clutch in and you can only hear it when your in motion. it gets worse the higher the closer you get to 5th gear.
Re: BAD BEARING IN MY TRANNY! [Re: trashcanman] #882173 04/22/08 06:44 PM
Snowtoy Offline
Marlins prices aren't that bad compared to what a friend paid years ago for a benchtop rebuild. You will also have to factor in double shipping costs, or core charge when considering a local rebuild or one of his.
To check the tranny w/o having to deal w/road/drivetrain noise,start up the engine and pt the t-case in neutral, you can then shift through the gears and listen to the tranny.
Re: BAD BEARING IN MY TRANNY! [Re: Snowtoy] #882174 04/23/08 06:33 PM
Red_Chili Offline
Toyota Section Staffer
Tranny rebuild at home...
if you run into a cost ceiling. The W56 is very similar.
-Bill
Re: BAD BEARING IN MY TRANNY! [Re: Red_Chili] #882175 04/25/08 01:35 AM
So I put the transfer case in neutral and reved it up in all the gears and it doesnt make that noise! does that mean its in the transfercase?
Re: BAD BEARING IN MY TRANNY! [Re: trashcanman] #882176 04/25/08 06:06 PM
Red_Chili Offline
Sounds like what I would investigate next...
-Bill
Re: BAD BEARING IN MY TRANNY! [Re: Red_Chili] #882177 04/25/08 08:24 PM
Staceman Offline
Remove the rear driveshaft (from the transfer case), rev again, in 2Hi repeat - 2WD, (not 4WD)
PHP: 7.4.33 Page Time: 0.079s Queries: 15 (0.076s) Memory: 0.6205 MB (Peak: 0.6982 MB) Data Comp: Off Server Time: 2026-10-24 13:09:08 UTC
