Re: 99 Amigo Hard Start [Re: TrooperII] #882348 09/18/08 02:20 AM
Bacho Offline
maybe not 20 but i would say more like 10. Yea, what can i say, i'm a busy guy..
I am trying to do some research before starting a new thread. Did you find your cure?
I replaced the sending unit on my girl friends 99 rodeo and now it seems to have the same problem. It takes 10-15 seconds cranking before it will start, once it starts it runs fine. If I mess with the key and run the fuel pump about 3 times before I turn it over it will start normally most of the time. Any suggestions? Is there a way an excess of air in the lines between the regulator and pump are the issue?
Re: 99 Amigo Hard Start [Re: Bacho] #882349 09/18/08 02:24 AM
Jim_Paget Offline
It seems to me that several years ago there were one or more threads that basically defined the issue as you have stated it. My memory is that the issue was the fuel was draining back away from the injectors when the vehicle sat for a while. I don't remember whether or not there was a TB or correction on the problem.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: 99 Amigo Hard Start [Re: Jim_Paget] #882350 09/18/08 02:37 AM
Bacho Offline
Ive searched back into 2005 or so, I cant see alot other than just the fuel regulator being talked about. Which I understand that sometimes stuff like that goes out on coincidence at the same time but I am doubting it. I dont see any talk of how I might have hurt it. Thanks for the reply.
Re: 99 Amigo Hard Start [Re: Bacho] #882351 09/18/08 11:55 PM
Bacho Offline
I found my problem, I found a small hole in the flexible fuel line in the pump. Must have been too fragile as old as it was. Anyways I replaced the pump and its good now.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6087 MB (Peak: 0.6808 MB) Data Comp: Off Server Time: 2026-06-07 07:28:58 UTC
