Door locks keep locking and won't stay unlocked! 94 SR #882552 04/24/08 02:50 PM
reknawj Offline OP
Hey guys, hoping that one of you knows this keyless entry thing.
Here's the problem...if I hit the lock door button (remote or door, any door) They all lock. When I go to unlock them (either method again) the locks go to locked when I release the button, all by themselves.
This has been happening for awhile and it's driving me nuts. The time has come to get rid of the gremlins.
And I don't want to disable the system as I like remote entry and I'll fix it one way or another.
Thanks for the help!
1994 Montero SR
Divide Colorado
Re: Door locks keep locking and won't stay unlocked! 94 SR [Re: reknawj] #882553 04/24/08 04:25 PM
Scottie2113 Offline
more than likely, you have a bad actuator in either of the front doors, more than likely the drivers door. There is a way to fix it without replacing the actuator, but you have to be good at prying apart the actuator that is glued together without breaking it and then you have to take the gears out and snip a wire or replace the little rubber stops that have over the years broken down. In a nut shell, there are little contacts inside the actuator that are used in the 'central locking system' Its complicated, I fixed it in one of my monteros, but I would recommend just getting a driver side door actuator from a part yard for 40 bucks and replacing it, its fairly easy. when the rubber contacts break apart, it lets the control gear (shaped like a pizza slice) travel past its normal range of motion and in turn the electrical contacts touch in a way they weren't designed to, so what is happening is when you unlock the truck, the actuator over extends itself and sends a signal to the central locking mechanism to lock the doors even though you never intended it to happen. the complicated fix is to open the actuator and either repair the rubber stops somehow or snip the green wire that is responsible for the central locking, your remote will still work, but opening the door with the key will no longer open all doors nor will the key lock all doors either. if I confused you, let me know, I will go into more detail. I did a long write up on this years back, don't know where it went though.
HTH
scottie
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Door locks keep locking and won't stay unlocked! 94 SR [Re: Scottie2113] #882554 04/24/08 07:15 PM
stony-man Offline
Our '95 has done that for over 5 years now. When you turn the key to unlock, hold it there for a second. Then they will not relock when you take the key out...or fix it right like the guy above described. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Door locks keep locking and won't stay unlocked! 94 SR [Re: Scottie2113] #882555 04/24/08 07:25 PM
Mine does the same, or at least it did until I yanked the fuse.
Re: Door locks keep locking and won't stay unlocked! 94 SR [Re: fasteddy] #882556 04/25/08 02:17 AM
Mine was a sticky mechanism in the rear gate. Opened up from the inside and lubed all I could get to. Has not proven to be fully cured but better. I expect another door or two is slow reacting causing the issue.
Re: Door locks keep locking and won't stay unlocked! 94 SR [Re: OldColt] #882557 04/25/08 03:12 AM
stony-man Offline
Man that makes perfect sense as my rear gate latch is always getting stuck (about every 18 months or so). <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Door locks keep locking and won't stay unlocked! 94 SR [Re: Scottie2113] #882558 04/25/08 05:56 AM
reknawj Offline OP
Thanks for the replies! No need to elaborate, It all makes perfect sense. Now, to find the time to start taking things apart. . .
1994 Montero SR
Divide Colorado
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6227 MB (Peak: 0.7142 MB) Data Comp: Off Server Time: 2026-06-07 07:22:41 UTC
