sway bar bushings #882766 04/26/08 02:55 PM
twholland Offline OP
Which of these polyurethane "FRONT SWAY BAR BUSHING SETs" will fit? BUSHINGS
'97 T100 XCab 4X4 SR5, 3" BL, 33x12.5 BFG A/T, Warn hubs, Ranchos
Re: sway bar bushings [Re: twholland] #882767 04/26/08 05:47 PM
BamZipPow Offline
Energy Suspension only made/tested this fer T-100s... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: sway bar bushings [Re: twholland] #882768 04/26/08 08:58 PM
E
eleet Offline
Measure your sway bar diameter.
There are a bunch of rubber donuts on the end links too.
97 T100 4x4
97 328i
95 540i restoration project
Re: sway bar bushings [Re: eleet] #882769 03/30/10 10:57 PM
BamZipPow Offline
4x4 stock front sway bar diameter is 27.107mm and end links measured out to be 2 7/8".
So...according to this 4x4wire article it should be Energy Suspension part number 8.5118G (black). At the moment, $14.40 plus shipping at Amazon or $18.40 at AutoZone... <img src="/forums/images/graemlins/smile.gif" alt="" />
End link part number comes out to be 9.8118G (black) or 9.8118R (red). $15.40 plus shipping at Amazon... <img src="/forums/images/graemlins/wink.gif" alt="" />
Fer the 2WD T-100...about $40 fer the set from AutoZone. <img src="/forums/images/graemlins/smile.gif" alt="" />
Sway bar bushings 1 1/8" (28.5mm) -- 9.5164R
End links (pair) 2 3/8" -- 9.8125R
How to measure end links sizing... <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: sway bar bushings [Re: BamZipPow] #882770 04/05/10 06:17 PM
BamZipPow Offline
So here's what I've found out so far...
Pulled the OEM part out of my 1993 T-100 SR5 2WD auto and it's stamped with 26.5 on the part. So I'm guessing 26.5mm. <img src="/forums/images/graemlins/smile.gif" alt="" />
On my 1998 T-100 SR5 extended cab 2WD auto, the OEM part is stamped with 28.6. So I'm guessing 28.6mm.
If you have the regular cab 2WD/4WD (non 1 ton) or a xtra cab 4WD T-100...yer gonna have to git the 27mm part (Energy Suspension #8.5118) and wrap some teflon tape around the sway bar to make up the .5mm difference (if it really matters to you).
If you have the 1 ton regular cab 2WD or xtra cab 2WD, then you git the 28.5mm/1 1/8" part (Energy Suspension #9.5164).
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6066 MB (Peak: 0.6733 MB) Data Comp: Off Server Time: 2026-10-21 20:43:08 UTC
