Ticking from Clutch / Transmission #882914 04/27/08 07:24 AM
MadGary Offline OP
I just had the transmission rebuilt and clutch with linkage redone on my 1980 CJ7 Golden Eagle 4 speed manual transmission. When I got it back, i noticed that when I have the clutch pedal pressed, there is a ticking / clanking noise coming from the tranny / clutch setup. As I take my foot off the the clutch, the ticking fades away, but not completely, and I can hear it until I get to about 40 MPH, then it seems to go away. It also makes the noise when I first start the car in neutral, but wont tick in neutral after I drive it for a bit.
I don't know a whole lot about Clutch assembly / setup, so is this a normal sound, or should I have them check it since its under warranty?
Re: Ticking from Clutch / Transmission [Re: MadGary] #882915 04/27/08 08:45 AM
BobRowe Offline
Take it back where you had the work done and have them do it right. It shouldn't be making the noise you describe.
Re: Ticking from Clutch / Transmission [Re: BobRowe] #882916 04/27/08 11:26 PM
kc77cj7 Offline
When I first got my Jeep the clutch made a weird sound and there was always a LOT of chatter/shudder. When I finally went to replace the clutch I found the previous owner didn't put in a pilot bushing. No wonder on the noise. Take it back to your shop, like BobRowe said, they should fix it no questions asked.
77 CJ-7 258 31" MTR's - now...
360, TF727, DANA 300, DANA 44's all sitting in the garage just waiting...
Re: Ticking from Clutch / Transmission [Re: kc77cj7] #882917 04/28/08 05:32 AM
MadGary Offline OP
Alright, I'll call them tomorrow. But just for a little more info, I dont hear the noise until the car gets warmer. I wont hear the noise for about, 15 miles as I drive to work in the morning.
Thanks for your replies. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6011 MB (Peak: 0.6564 MB) Data Comp: Off Server Time: 2026-05-30 00:54:49 UTC
