89 raider differential parts #883066 04/28/08 04:11 AM
Torsion Offline OP
Hello, I just bought an 89 Dodge raider V6. Over all it's in pretty good shape. I just ordered a set of KYB shocks for it. I really need info on where to buy replacement gears for the rear differential. I think it's going bad. When ever I take off from a stop and turn right or left there's a terrable vibration from the rear. Any help would be appreciated. [Linked Image]
89'Dodge Raider 3.0 V6, A/T
LSD, KYB equipped
Re: 89 raider differential parts [Re: Torsion] #883067 04/28/08 05:12 AM
It looks like you have the limited-slip differential (LSD) rear axle, based upon the presence of headlight washers. What you're feeling is the engaging LSD controlling the wheel spin. If you stomp on the gas, both rear wheels will get power. I can lay about 1 foot of rubber with my 87 Raider 4-cyl. !! I would advise changing the fluids, making sure to add the traction additive to the rear axle. You'll soon grow use to the feeling of turning with the short wheel base and the LSD action. Nice truck and welcome to the Wire!! <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: 89 raider differential parts [Re: Torsion] #883068 04/28/08 05:28 AM
DirtDriver Offline
THAT is one amazingly clean Raider! Looks like you just drove it off the dealer lot. <img src="/forums/images/graemlins/kewl.gif" alt="" /> How about a little history--previous owner, mileage, price paid. We like to hear that stuff here.
If Russell's suggestion doesn't fix it, you can swap it with a junkyard axle. You want to find one that has the LSD. There's an orange sticker on the driver's door jam. Make sure the donor has the same gearing; you can check the data plate under the hood, passenger side front.
If you plan on doing any wheeling, and don't mind modifying it from stock, then it would be a very good idea to put in a rear end from a Gen2 SR. Lots of advantages if you plan on getting it dirty. writeup here
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
Re: 89 raider differential parts [Re: rxinhed] #883069 04/28/08 06:06 AM
DirtDriver Offline
I just remembered--Mitsubishi has special LSD gear oil. Probably better than trying to guess the right mix of regular gear oil and friction modifier. Especially if you want to make sure that's the problem. PN 3775610.
Re: 89 raider differential parts [Re: Torsion] #883070 04/28/08 06:28 AM
CapnCrunch Offline
Where be you located? As mentioned, that looks like a really clean truck and I'm curious if it has any rust at all.
Welcome to the wire! <img src="/forums/images/graemlins/cheers.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 89 raider differential parts [Re: CapnCrunch] #883071 04/28/08 03:05 PM
hazy_daze Offline
While your under it, check your u-joints too.
Nice looking truck and welcome to the Wire <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6143 MB (Peak: 0.6857 MB) Data Comp: Off Server Time: 2026-06-21 12:23:50 UTC
