Weird starting/running issue 22RE #883293 04/29/08 01:51 PM
Nix_Toy Offline OP
Hey everyone, I kind of have a problem with my truck. When I used to start the truck for the first time in the morning, it would fire right up, and (i think) be running on 3 cylinders for about 30 seconds, and then smooth out. After the initial starting of the truck for that day, it would always fire up running smooth. Well, I went on vacation for a month, and when I came back, my truck became a little harder to start, it takes a little bit of cranking to catch, and when it does, it feels like it's running on about 2 cylinders! But after a minute, it'll smooth out. But when I park to get gas or something, then try to start my truck again (with engine warm) it takes A LOT of cranking for the engine to catch, and the same thing, runs on 2 or 3 cylinders... but after that everythings fine.
Spark plugs, wires and rotor were replaced about 6 months ago because of the original 'problem,' although it never fixed it. Anyone have any ideas?
Thanks for any help!
-Nick
Edit: But my truck still manages 25mpg, so I dont' complain that much.
Re: Weird starting/running issure 22RE [Re: Nix_Toy] #883294 04/29/08 03:51 PM
4Crawler Offline
Might try the fuel pump test jumper to see if that helps:
- http://www.4crawler.com/4x4/CheapTricks/index.shtml#FuelPump
And maybe check the fuel injector wire splices, several threads on that subject on this forum over the last few years. Might have a loose connection in one of the splices that is causing the running on 2 or 3 cylinders.
Re: Weird starting/running issure 22RE [Re: 4Crawler] #883295 04/29/08 04:19 PM
Nix_Toy Offline OP
Oh yea, I've had the fuel pump jumper in for awhile now.. the pump always turns on. I forgot to mention that when it's cranking, you can definatly smell fuel, so I'm pretty sure it's getting it.. but I'll check the splices later today. Thanks
Re: Weird starting/running issure 22RE [Re: Nix_Toy] #883296 05/03/08 05:33 AM
datsun_73 Offline
Have you checked cold start injector? Should not be fuel pump, wires and plugs if she runs smoothly with hot engine.
good luck! keep us posted! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Weird starting/running issure 22RE [Re: datsun_73] #883297 05/06/08 08:23 PM
Nix_Toy Offline OP
Not really sure if it's the cold start injector.. how does one go about checking it? I know where it is, but have no clue if it's working. Also, would that cause the engine to run on 3cyl for about 30 seconds? Thanks.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6095 MB (Peak: 0.6747 MB) Data Comp: Off Server Time: 2026-05-29 16:15:04 UTC
