Fix...or rebuild?
#883343
04/29/08 04:59 PM
Ok heres the scoop guys n gals...i have an 87 truck with the 22r, the motor has been to hell and back and wont last much longer if i were to guess. The #2 rod journal on the crank is toast and is knocking, and the #2 exhaust lobe on the cam is now completely round <img src="/forums/images/graemlins/drunk.gif" alt="" /> compression is good. Could the excessive wear on the crank and cam be connected in anyway???
I also have a 82 22r layin around with a good crank and cam.
I know there are differences between the 87 and 82 22r's so can i swap the crank and cam and throw new bearings into the 87 or would it be better to rebuild the 82 (even though i dont have the intake/ exhaust mans. and everything else) and drop it in the truck. This truck is my beater so my goal is to get it running decent within the near future. Thanks.
88' Xtra cab, 22RE, 5 spd, alumi flat deck, 3" BL, 35" muds...awaiting SAS.
'02 Ram, 4.7, REV 'Shooter' wheels wrapped with M.T. Baja claws.
Re: Fix...or rebuild?
[Re: PETE_YK]
#883344
04/29/08 05:48 PM
>>>*Morning!
The early crankshaft is identical, note the rod beams are slightly different in the early set but they will bolt in in sets and work just fine.
If out of a running unit the weights won't be a concern that way, Toyota is very good at balance on these engines.....*EB
*Beats the he** outa me!....*LOL**...
[Re: engnbldr]
#883345
04/30/08 07:58 PM
The rod beams??? bolt in in sets? Please explain.
How about the cams, are they interchangeable?
Thanks.
[Re: PETE_YK]
#883346
04/30/08 11:56 PM
>>>*The beam of the rod is the section between one end and the other, the design is slightly different from early to later models.
Yes, use in sets. 4 from one engine is a set, the weights need to match. Or have them balanced.
Yes, all the cams interchange....*EB
[Re: engnbldr]
#883347
05/01/08 06:29 PM
hmm...swaping the rods adds a curve ball...i was hoping to do it with the engine still in the truck <img src="/forums/images/graemlins/drunk.gif" alt="" /> Are the pistons the same as well?
