2.6l oil filter mount?? #883417 04/30/08 12:59 AM
I
Idaho_Trooper Offline OP
So I was out driving my SAS Trooper the other day and evidently I managed to take out the oil filter with the front axle. <img src="/forums/images/graemlins/scared.gif" alt="" /> It broke off the threads for the oil filter with it when it went. Does anyone know if this part is separate from the oil pump, or do just replace the oil pump and this piece is a part of it?
BTW, the rig WAS driving great until this happened. <img src="/forums/images/graemlins/smile.gif" alt="" /> I don't have the shocks on it yet or the bump stops, and I hit a big construction hole at 45mph! I may make Moab this year.... Will be mounting up the rest of this stuff this weekend. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
James "MOZES" Tester
1988 Trooper SAS
Re: 2.6l oil filter mount?? [Re: Idaho_Trooper] #883418 04/30/08 02:19 AM
4xToy Offline
That piece is just an adapter. It has nothing to do with the oil pump. Just find you another one and replace it, is all you can do.
Chad
-Chad
Re: 2.6l oil filter mount?? [Re: 4xToy] #883419 04/30/08 02:25 AM
I
Thanks for the post Chad.... I will try and find one local.
1988 Trooper SAS
Re: 2.6l oil filter mount?? [Re: Idaho_Trooper] #883420 04/30/08 04:53 AM
randii Offline
Chad nailed it -- replace the piece, you've only damaged external parts. I had a similar problem (kept kinking oil filter cans) and ran a shorter filter can for a while, after comparing a bunch of 'em for threads and size (sorry, I don't remember the specs). I ended up cutting and tapping the aluminum bolt-on fixture for the pump and running an external oil filter... that worked grand until the cheap-o hoses that came with the kit crapped out and drained all my oil on the freeway. <img src="/forums/images/graemlins/frown.gif" alt="" /> If you use good hoses, this is the route I recommend.
Get some shocks and bump stops and get to Moab!
Randii
Re: 2.6l oil filter mount?? [Re: randii] #883421 05/04/08 04:09 AM
I
Got her fixed up. $20 and three hours later I had it done!
I am trying to post pics, but I am not very good at it....
1988 Trooper SAS
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6063 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-05-29 15:38:25 UTC
