flashing frontwheel lites on 96 monty LS #883436 04/30/08 02:52 AM
chris40 Offline OP
the front wheel lites come on and off at random on my 96 montero,it now flashes pretty much all the time.I tried moving the stick back an forth,i tried looking at all the old post but found nothing. this problem would appear to be electrical, i would go into the store and get back in and the flashing front lites are gone leaving just the green rear lites on solid,please help.
Re: flashing frontwheel lites on 96 monty LS [Re: chris40] #883437 04/30/08 04:03 AM
Welcome...
Search '+flashing +front' (w/o quotes) and you'll find plenty of threads.
Re: flashing frontwheel lites on 96 monty LS [Re: chris40] #883438 04/30/08 10:24 PM
Scottie2113 Offline
what I have found to be the problem most of the time with this is the two little solenoid valves that operate the free-wheeling clutch actuator on the front axle. over many years they either go bad or get sticky or dirt in the moving valve part. they are located on the passenger side in the engine compartment on the top of the fender well. there should be one with a blue dot and the other with a yellow dot. if you are good at taking things apart, you can unbolt them and disconnect them and spray some cleaner through them hook the plugs back up and work them back and forth and try to clean them out, sometimes they seem to get sticky over the years. if that doesn't help, you may need to replace them. the actuator works on a vacuum system. I am pretty sure that if my memory serves me well, the yellow dot is for keeping it in 2wd and the blue dot assists at putting it in 4wd. your yellow dot solenoid is probably the culprit. keep in mind, that actuator on the front axle is already spring loaded, so at rest without vacuum, it always wants to be in 4wd mode (free wheeling clutch activated). the only thing that keeps the front axle disengauged (2wd) is the vacuum through that yellow dot actuator. when you put the truck in 4wd, it basically takes vacuum away from the yellow dotted line and applies vacuum to the blue dotted line to 'assist' in locking in the front axle free wheeling clutch. now even without the blue dotted line working, the spring load of the actuator would eventually put in 4wd, but the blue dotted line helps this process as it needs more force to go into 4wd than to come out of 4wd. i hope this helps and if I confused you let me know.
scottie
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: flashing frontwheel lites on 96 monty LS [Re: Scottie2113] #883439 05/01/08 02:58 AM
chris40 Offline OP
thanks scottie,i did find both actuators,i will try cleaning them out along with the connectors,i will let you know thanx again
Re: flashing frontwheel lites on 96 monty LS [Re: MontyMcV] #883440 05/01/08 03:08 AM
chris40 Offline OP
hey i went on mitsubishilinks.com i did not see where to type in flashing fronts. good site
Re: flashing frontwheel lites on 96 monty LS [Re: chris40] #883441 05/01/08 03:46 AM
Angelo Offline
Mine blinks all the time! <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> I just left it as is cause I already know its the 4wheel drive ECU. My truck engages and disengages just fine, it just blinks at me <img src="/forums/images/graemlins/angry.gif" alt="" />
How much is one of those things while on the subject <img src="/forums/images/graemlins/drunk.gif" alt="" />
Chris, find out if it is disenaging or not. Plus, I have a huge article from the Outerlimits board, was very very helpful. Cant seem to find it right now. Someone might chime in with the link
best of luck,
Angelo
Re: flashing frontwheel lites on 96 monty LS [Re: chris40] #883442 05/01/08 06:32 PM
ryany Offline
Search this site, not mitsubishilinks.com. Go up to the top of this page & click on 'search' right next to 'index'. The search function is a bit touchy, but read the instructions & play with it a little bit & you'll find what you're looking for.
95 Montero SR
Re: flashing frontwheel lites on 96 monty LS [Re: ryany] #883443 05/01/08 08:19 PM
93montero_sr Offline
Mine blinks to at freeway speeds but i think its just my swampers viberating the sh*t out of my manual hubs <img src="/forums/images/graemlins/notooth.gif" alt="" />
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
Re: flashing frontwheel lites on 96 monty LS [Re: 93montero_sr] #883444 05/01/08 09:15 PM
Scottie2113 Offline
I bet there is a vacuum leak somewhere in the yellow line that goes to your front axle, at higher engine speeds there is less vacuum and it could cause your free wheeling clutch to 'flutter' on the highway.
angelo: I am not so sure it would be your ecu. if you can find the wire that is going to your front axle, try unplugging it and see if the blinking changes. if not, then try grounding the wire that goes up into the truck, see if that changes the blinking.
scottie
Re: flashing frontwheel lites on 96 monty LS [Re: Scottie2113] #883445 05/04/08 12:57 AM
3
3esso Offline
Mine WAS blinking when I first got my car
I found this website very helpful in fixing the problem, my faulty part was the solenoids one was bad.
here is the web site:
http://4wd.blogeasy.com/
and as a temporary fix to the blinking light I re-arranged the vacuum lines "some how" I don't remember exactly, to only send vacuum to the front diff. in this case I cant engage 4X4 by any how other that replacing the right lines to their origenal positions.
anyway my blinking issue stoped after I replaced the two soleniod valves
96 NJ SWB 3.5 pajero(Bone stock)
84 NA Hi-roof Pajero(also Stock)
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6406 MB (Peak: 0.7646 MB) Data Comp: Off Server Time: 2026-06-10 01:55:27 UTC
