won't crank #883583 04/30/08 10:44 PM
bud89 Offline OP
i have an 89 cherokee was running great stopped at daughters bus stop shut it off now it won't start its getting spark and fuel.
Re: won't crank [Re: bud89] #883584 04/30/08 11:01 PM
BigJim Offline
First thing I'd do is pour an oz or 2 of gasoline into her and SEE FOR SURE she was getting gasoline..
If she don't pop and snort then I'd know for sure she had a spark problem.
I'd get my wife to hold a plug wire and see how high she jumped when I turned the engine over.. If she starts beating me about the head and shoulders.. I'd know the timing was off and THAT was the problem.
The timing is controlled by the computer.. Mostly it gets it's main information from the CPS to know when to spark correctly.
Even if it was an iac or a tps the engine should at least start.. or nearly start.
Then last but not least the timing chain could have jumped a cog..which is not unheard of but not common with Jeep engines.
Big Jim
Re: won't crank [Re: bud89] #883585 04/30/08 11:50 PM
bud89 Offline OP
thanks for info got it running now i feel stupid the wire on the ceramic block was broken at the connector, when i went back to jeep i remembered this happening to me on an old blazer so i checked it an it fired right up
Re: won't crank [Re: bud89] #883586 05/01/08 03:07 AM
BigJim Offline
So that would cause you to NOT have the spark that you posted..huh?
Re: won't crank [Re: BigJim] #883587 05/02/08 10:28 AM
E
el_d_m Offline
that shuts off the fuel pump. that is $5 part that you should keep 2 of in your glove box!! i break them alot on my xj.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6038 MB (Peak: 0.6681 MB) Data Comp: Off Server Time: 2026-07-16 22:47:20 UTC
