won't crank
#883583
04/30/08 10:44 PM
i have an 89 cherokee was running great stopped at daughters bus stop shut it off now it won't start its getting spark and fuel.
Re: won't crank
[Re: bud89]
#883584
04/30/08 11:01 PM
First thing I'd do is pour an oz or 2 of gasoline into her and SEE FOR SURE she was getting gasoline.. If she don't pop and snort then I'd know for sure she had a spark problem. I'd get my wife to hold a plug wire and see how high she jumped when I turned the engine over.. If she starts beating me about the head and shoulders.. I'd know the timing was off and THAT was the problem. The timing is controlled by the computer.. Mostly it gets it's main information from the CPS to know when to spark correctly. Even if it was an iac or a tps the engine should at least start.. or nearly start. Then last but not least the timing chain could have jumped a cog..which is not unheard of but not common with Jeep engines. Big Jim
Re: won't crank
[Re: bud89]
#883585
04/30/08 11:50 PM
thanks for info got it running now i feel stupid the wire on the ceramic block was broken at the connector, when i went back to jeep i remembered this happening to me on an old blazer so i checked it an it fired right up
Re: won't crank
[Re: bud89]
#883586
05/01/08 03:07 AM
So that would cause you to NOT have the spark that you posted..huh? Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: won't crank
[Re: BigJim]
#883587
05/02/08 10:28 AM
that shuts off the fuel pump. that is $5 part that you should keep 2 of in your glove box!! i break them alot on my xj.
93 xj stroked 4.2 w/4.0 head avenger supercharged 6.5" long arm 35" buckshots rubicon 44's front & rear
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6024 MB (Peak: 0.6666 MB) Data Comp: Off Server Time: 2026-10-21 22:02:43 UTCValid HTML 5 and Valid CSS
