Removing the Dash, need some help
#883588
04/30/08 11:09 PM
I have the vehicle stripped of interior for Herculiner, and I thought I'd pull the dash to clean out the vents, but it's giving me trouble. I removed the 12mm side bolts and the 12mm nut behind the center gauges, but it's still stuck, can anyone help? I'm taking pics along the way so maybe I can help someone else at a later date.
1989 Raider 3.0 5 speed 225K Possible rebuild about 30k ago, no proof. Dual Bouncy seats, HL washers. New Mud King 235's on 15x7 Crager soft 8's. Dark tint. Superwinch hubs. Herculined Interior.
Re: Removing the Dash, need some help
[Re: Jon94JGC]
#883589
05/01/08 02:12 AM
Download the 89 manual from www.mitsubishilinks.com and see if you got all the mounting bolts.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
[Re: DirtDriver]
#883590
05/01/08 02:30 AM
You'll need to look at the BODY sub-section (23), starting at page 72.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#883591
05/01/08 03:18 AM
Thanks guys, I found the last two bolt/nuts. You have to pry up the side window defroster vents, there are nuts behind them. Now that my dash is out, should I throw in a heater core, or anything while I'm in there?
[Re: Jon94JGC]
#883592
05/01/08 03:31 AM
[Re: hazy_daze]
#883593
05/01/08 04:15 AM
[Re: Jon94JGC]
#883594
05/02/08 05:37 AM
Well done, m8! Those vents really needed a good cleaning!
The heater core might be worth a look, but do you want to spend the ~$300 for a new one? Since you know how easy it is to remove the dash now, you can always replace it if you had to. <img src="/forums/images/graemlins/ignore.gif" alt="" />
[Re: DirtDriver]
#883595
05/03/08 02:45 AM
I agree, I looked at it while I was in there and it looked fine (like I would know what a bad one looked like)
now that I know how to remove the dash, it will be no big deal if the heater motor, or evap core, or anything else goes bad.
[Re: Jon94JGC]
#883596
05/03/08 02:57 AM
IMHO removal is usually easier than replacement/reassembly. <img src="/forums/images/graemlins/lol.gif" alt="" />
JK... sort of anyway.
Glad to see you got it apart w/out issues. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Jon94JGC]
#883597
05/03/08 07:30 AM
Since you have it apart, can you tell me if there looks to be enough room for a vertical tube (for a cage) to penetrate the dash and go to the floor? I'm curious if there's any sheet metal/ducting that will prevent this in the left and right corners by the windshield frame.
Thanks in advance for any assistance you can give.
73 -Jon KJ6GVM As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter Grampa's Trooper 1974 FJ40 1987 FJ60
