injectors #883681 05/01/08 11:08 AM
mgd4me Offline OP
i have a 94 ex cab,blew the head. i put a 89 motor in, ended up with leaky injectors on 1 and 2 cyl. the injectors were from the 94. i had to splice in 2 of the 89 injectors.(i dont like) the q: are the injectors the same? i never had a problem b4 the chance over..
94 ex cab 3" body...33" bfgs... 1 roll over..stocker
http://www.youtube.com/watch?v=tYlDedAt96Y
Re: injectors [Re: mgd4me] #883682 05/01/08 12:44 PM
Ganoid Offline
The only difference would be the resistance. Check the resistance across the terminals with an Ohm meter, they will be either high(10-16 ohm) or low(1.7-3 ohm). You need to keep the injector resistance to match what ever resistance came with the ECU. If your 94 had high resistance injectors then you need to keep high resistance injectors on that ECU or you may damage it, Same applies to low resistance. The flow rates should be the same but there was a point where Toyota changed the resistance values for the injectors.
90 Xcab V6
3.0 Rebuilt/Balanced
P/P w/OS valves
Downey Hdrs,Jacobs Ign
5.29's,Tru Trac+Lockright
4"TG SAS+Rear Kit on 35's
(DOA Racing = $1200 lesson <img src="/forums/images/graemlins/angry.gif" alt="" />)
www.performancecylinderheads.com
Re: injectors [Re: Ganoid] #883683 05/01/08 04:44 PM
Staceman Offline
x2
On this topic, are the electrical connections for the 2 different resistant values the same on each? Or is the "plug" different?
Re: injectors [Re: Staceman] #883684 05/01/08 09:33 PM
Adam F Offline
Yes, plug is different. Looks the same, but there is a little tab that wont let you plug one into the other.
97 4R, stock, daily driver
Re: injectors [Re: Ganoid] #883685 05/03/08 01:43 PM
mgd4me Offline OP
thanx ganoid..thath what i was thinking..then why did the leak stop when i changed injectors? o-rings seat rite?..or just a fluke?
Re: injectors [Re: mgd4me] #883686 05/03/08 03:02 PM
Adam F Offline
Most likely the o-rings.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6119 MB (Peak: 0.6817 MB) Data Comp: Off Server Time: 2026-06-07 07:26:35 UTC
