Turn signals failure #883927 05/03/08 12:42 AM
Drewz Offline OP
Cant explain it but my turn signals just stopped working today. I checked the fuse and its good (I replaced it to be safe) The switch feels tight and connected well to the steering column. Any one else had this happen...I'm not much on electrical so i would hate to follow the wires...any thoughts? <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks,
Drew
91 Monty RS stock sitting on 31's w/polished Alum 16"s 265,000 orig.
Re: Turn signals failure [Re: Drewz] #883928 05/03/08 12:59 AM
CapnCrunch Offline
If the signal turns on, but doesn't flash on-and-off, check to see if one of your bulbs is burned out. If the bulbs are fine, it may be your flasher relay, located under the dash on the left side. It could also be your hazard-light switch, but check the others first.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Turn signals failure [Re: CapnCrunch] #883929 05/03/08 10:20 AM
Drewz Offline OP
Emergency flashers work fine. I'll check the relay. Thanks!
Re: Turn signals failure [Re: Drewz] #883930 05/03/08 02:20 PM
Flashers can work and turn signals not, and the problem be the hazard switch. If Capn's other suggerstion don't find the problem, then his last on the switch would be your next.
Re: Turn signals failure [Re: MontyMcV] #883931 05/04/08 02:16 AM
G
generation_one Offline
Me too, the switcharoo
seem to rember the blinker cicuit going through the hazrd switch. can be pulled out and jumpered for temporary fix.\
consult your diagram!
1989 5 door montero 3.0 auto
stock original Japanese
about 200k miles
Re: Turn signals failure [Re: CapnCrunch] #883932 05/12/08 04:35 AM
Drewz Offline OP
Thanks for the help...it was the Flashers relay. A 2.95 fix! YAHOO!!!!
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6111 MB (Peak: 0.6808 MB) Data Comp: Off Server Time: 2026-05-29 23:57:11 UTC
