'87 Trooper clutch adjustment
#884146
05/04/08 08:03 AM
How would I go about adjusting the clutch cable on my '87? It shifts fine and the clutch works good. However, it makes a really annoying squeeling sound when the clutch pedal is fully released. If you barely push the clutch in, say maybe a 16th of an inch or so, the squeeling stops and all is good. How would I adjust this? Or do I adjust the clutch pedal? Its not going to take much. Thanks.
Re: '87 Trooper clutch adjustment
[Re: Jim_Welsh]
#884147
05/04/08 03:54 PM
Try adjusting the cable. 1. Loosen adjusting nuts on cable at firewall just beside brake master cylinder 2. Pull cable forward and tighten 3. Back off nut until there is appx 5mm clearance between firewall and nut 4. Tighten locknuts together
If this doesn't work, then you probably need a clutch
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5861 MB (Peak: 0.6341 MB) Data Comp: Off Server Time: 2026-07-15 14:42:57 UTCValid HTML 5 and Valid CSS
