Wheel swap for 91 Trooper #884188 05/04/08 08:47 PM
BillW Offline OP
I've searched for this and I seem to get stuff that helps but nothing that completly answers my questions. I have a 91 Trooper with the stock alum wheels and tires (235R15),I think they are being refered to as snowflakes. I really like the look of the stock alum wheels on the 99 and later Troopers, they look like a 5 spoke design and I think they are 16's. There is a salvage yard here with a set that I think I can pick up pretty cheap. My question is will they fit, do they have the same bolt pattern, will anything rub on the rim or tires. If they do fit what do I need to do to make the speedo correct and how will it effect my gas mileage, I know it takes a little more effort to turn the bigger tires but they also travel a little farther on each rotation.
91 LS Trooper 3.4 w/225k
BillWhitbeck@grovesigncompany.com
Re: Wheel swap for 91 Trooper [Re: BillW] #884189 05/05/08 03:35 AM
jezeric Offline
Isuzu Moderator
Shouldn't have any problems with the wheels. I went from 15" steelies on my Rodeo to the 16" alloys with no problem at all. Should be a bolt-on change.
James
Re: Wheel swap for 91 Trooper [Re: BillW] #884190 05/06/08 02:35 AM
Ed Mc Offline
Bill, when going to a larger tire size you'd need to change the plastic gear in the speedo drive assy bolted to your tranny. This is simple and I've done it in a P'up before without draining the tranny oil. Just elevate the rear and unbolt/slip out gear-install new/reinstall drive assy.
Jerry Lemond can probably get a good used gear with the correct # of teeth for your application so you might get hold of him. I don't know if they're still selling these new.
I was planning on going from LT235's on my 3.4 Trooper to larger tires. I have a nice set of 31X10.5-15's which should provide about "1-gear-taller" gearing. I'd expect that'll cut down on hiway rev's a bit and the 3.4 should certainly be able to pull it! Turning way too fast at 60 right now and with gas prices going thru the roof, any bit helps.
You can figure out the percentage change with the larger tires you plan on installing. That'll let you compensate for odometer readings until you change out the speedo drive gear. Otherwise your mpg calc's will be skewed and you won't be able to tell if the larger size actually helped or hurt.
Here's a real handy tire dia calculating tool:
http://www.1010tires.com/tiresizecalculator.asp
HTH & let us know how it works out............ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5966 MB (Peak: 0.6503 MB) Data Comp: Off Server Time: 2026-05-29 22:21:04 UTC
