Gas #885084 05/10/08 02:10 PM
Superman Offline OP
In the recent gas crisis, I have been finding ways to get more mileage.
This is the exact same specs for my truck.
http://www.edmunds.com/used/2003/toyota/tacoma/100175738/specs.html
The specs said that:
Code
Fuel
Fuel Tank Capacity: 18.5 gal.
EPA Mileage Estimates: (City/Highway)
Automatic: : 17 mpg / 19 mpg
Range in Miles: (City/Highway)
Automatic: 314.5 mi. / 351.5 mi.
I don't understand. At my best driving, I am getting 300 mi on a full tank. But than again, that is because I run the tank down to about 98%.
It has always been like this. I have only got 310 mi once. Am I suppose to run with Over Drive on?
Clark
Tacoma PreRunner Double Cab V6 Automatic
3.4-liter V6 TRD
Re: Gas [Re: Superman] #885085 05/10/08 04:37 PM
humanoid Offline
You mean you don't use overdrive? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Gas [Re: humanoid] #885086 05/10/08 11:13 PM
Superman Offline OP
I thought turning OverDrive is only for mountain roads?
Clark
3.4-liter V6 TRD
Re: Gas [Re: Superman] #885087 05/10/08 11:29 PM
Coyotekid Offline
NO NO NO!!!
You DON'T use overdrive on mountain roads!
You use it on freeways,/highways and such!
lol..
Your Mileage will improve ALOT on the freeway if you use OD on the freeway
<img src="/forums/images/graemlins/smile.gif" alt="" />
-Dano-
<img src="/forums/images/graemlins/rolleyes.gif" alt="" />
~~~The more People I meet, the more I like My Dog..~~~
-96' Tacoma 3.4 4x4 5 Speed, Trueflow intake+Deckplate, 2.5 inch Magnaflow Cat-back,OME 881's, and some extra-leaves in the rear..
-68' Chevelle Malibu..Stage one of Restoration: *Collecting funds* <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Gas [Re: Coyotekid] #885088 05/11/08 01:12 AM
Superman Offline OP
Cool, I see. Please help answer these questions.
When is the rule of thumb to turn-on OverDrive? Above 40 miles?
Also, when I turn off my engine, it turns off. Is that normal?
If I drive with OverDrive on regular surface roads, will it harm my engine?
All these years, I have been driving with OverDrive off, is that bad for the engine?
Clark
3.4-liter V6 TRD
Re: Gas [Re: Superman] #885089 05/11/08 02:22 AM
BIGBURLYNAKEDMAN Offline
Is this a joke? <img src="/forums/images/graemlins/confused.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: Gas [Re: BIGBURLYNAKEDMAN] #885090 05/11/08 03:44 AM
Superman Offline OP
This is for serious. I wouldn't post it if I knew. Sorry if it sounds ignorant. I would appreciate if you can help.
Clark
3.4-liter V6 TRD
Re: Gas [Re: Superman] #885091 05/11/08 04:17 AM
What the Overdrive itself does is save you gas by bringing the RPMs lower during normal driving. It's almost like having one more gear to your tranny.
If you're driving in hilly or steep territory, and you find that the truck is bogging down or frequently has to step down into 3rd gear (i.e. out of overdrive) to keep speed, then you should push the button to take it OUT of overdrive mode (that's when the O/D OFF light illuminates). What that does is keep your truck going in 3rd gear: no converter lockup or overdrive. This gives you more power for steep grades since it keeps the truck in the meat of its powerband, but kills your gas mileage for everyday city, freeway, or whatever driving.
So basically, only use that button if you're going up a steep hill or if you want to use the engine-braking effect to use your brakes less while going down a steep hill. Make sense?
Re: Gas [Re: Superman] #885092 05/11/08 05:57 PM
humanoid Offline
As stated earlier, the OD is just an extra gear. Use it on the highway. I have the OD on the whole time, it won't hurt the engine or tranny.
Re: Gas [Re: Superman] #885093 05/11/08 07:46 PM
Jeff the marmot Offline
Hint: When you push the Overdrive button and the light on the dash turns on, it turns overdrive OFF.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6375 MB (Peak: 0.7618 MB) Data Comp: Off Server Time: 2026-06-23 15:24:10 UTC
