no air #885755 05/14/08 01:18 PM
snowboardvdr Offline OP
i was getting hot the other day and went to turn on my air con. nothing happened. i stopped and turned it on, heard the compressor turn on but not the blower. checked the fuses they are all ok. so anyone have any clue? its gonna b a hot summer up here and i need it. help <img src="/forums/images/graemlins/cheers.gif" alt="" />
if speed kill do brakes give life?
Re: no air [Re: snowboardvdr] #885756 05/14/08 02:04 PM
Dave Scott Offline
plug under glove compartment. mine came unplugged once.
Re: no air [Re: Dave Scott] #885757 05/14/08 03:35 PM
Hydra747 Offline
If that doesn't work then...........
Try to see if it is the Blower Motor Vs. the Resister:
1) Run an active (hot) pos. lead to the blower and make sure that it is grounded------When it runs then---The blower motor is fine.
2) Then one should suspect the Resistor box (Don't attempt to repair) Get a new one!
BTW---Sometimes they burn out like mine have! <img src="/forums/images/graemlins/kewl.gif" alt="" />
As Everet says, and I'll say-------Should be a 6 cocktail job! <img src="/forums/images/graemlins/cheers.gif" alt="" />
You see I'm in south TEXAS and if my AC burns out I will do anything to get that sucker running!!! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: no air [Re: Hydra747] #885758 05/15/08 01:44 AM
the wire under the glove box is attached. i turned it on and smelled something burning. couldnt find it tho. seems to b comming from inside the dash. gonna take the dash apart on my next day off. how diff is it to replace the motor?
Re: no air [Re: snowboardvdr] #885759 05/15/08 06:02 AM
bombardj1 Offline
I guess it depends on the year I replaced a 2001 in about 15 min. the motor on the 2001 is up under the passengers side behind glove box the blower resistor switch is in the same area,
Re: no air [Re: bombardj1] #885760 05/21/08 07:19 PM
logansportage Offline
I've had the same problem with my 98. The only setting that worked was to put the fan in position 4 and it would work.
Try that.
If so the resister has melted the contacts and just needs to be resoldered onto the contact pads. Easy job to fix. No where near 6 cocktails. Unless you are Everet and drink all the time anyway. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Just giving you crap Everet.
Pull the electrical connector off and remove the two screws. The resistor will fall right out. You will need to use a thin flat blade screw driver to slightly bend the retaining pins so you can remove the black plastic housing. Look at both sides of the heat sink and you'll probably notice the ones that have come off the electrical pads. Just heat them up with a soldering iron to reflow the solder and put it all back together.
Use a Philips screw driver to bend the pins back to hold the plastic housing in place.
Re: no air [Re: logansportage] #885761 05/21/08 07:54 PM
Hydra747 Offline
That is funy! Watch it, Everet is my best friend!<img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: no air [Re: Hydra747] #885762 05/21/08 11:19 PM
No he's not, he's mine! I saw him first. <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: no air [Re: logansportage] #885763 05/22/08 01:41 AM
ive tried the fan on its highest setting and it still wont run, should i get a new resister? or does it come with the new blower motor? i have friday off so im gonna do it then. thanks guys <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: no air [Re: snowboardvdr] #885764 05/22/08 06:09 AM
bombardj1 Offline
no you don't get the resister with the blower motor, pull the blower and see if it will spin, make sure you have it disconnected from the wiring harness, you should also pull the resister to see if any of the tabs have melted the connect's, go from there.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6374 MB (Peak: 0.7633 MB) Data Comp: Off Server Time: 2026-10-21 22:05:43 UTC
