3vze valve cover tube??
#885811
05/14/08 06:01 PM
is the small tube connecting the passenger side valve cover to the air chamber needed? mine has been broken(but in place) for a while and i am going to do the valve cover gaskets so should i replace it and if so does anyone know the part #. i checked the #thread but i think it gves the # for the grommet but not the actual tube.thaks to all.
Re: 3vze valve cover tube??
[Re: yekrahs]
#885812
05/14/08 07:30 PM
i took and replaced the upper intake tube that goes between the throttle body and the middle resonator with a spector intake tube. when i did that, i replaced the tube with a small filter from auto zone. that tube is just to vent air into the crank case.
formerly 277000_yota Old enough to know better, but still to damn arrogant to care... ]www.cardomain.com/ride/2614269'90 'Yota 4X4 (10/31/05-09/10/08 R.I.P) '98 'Yota t-100. 3.4, 5 sp. 4x4, 2 in. Toytec with BFG A/T 265/70R16s
[Re: IceBlueT]
#885813
05/14/08 08:30 PM
Unless you are in a state that does a visual inspection when you have to have it smogged the answer is no. In fact it is a good idea to take them off the air cleaner and run them in to a catch can. Those hoses are the reason that the 3.0 will hydro-lock if it is laying on its side for a while after a flop. The oil runs up into the valve covers, into the hose, into the aircleaner and is sucked into the engine when you try to start it.
"Serenity through Sobriety"
[Re: OOP'S]
#885814
05/22/08 06:11 PM
thank you for the info. should i just plug the holes where the tubes went into the air chamber and resonator tube?
[Re: yekrahs]
#885815
05/23/08 03:50 PM
OK so i finished the valve/cam cover job and have everything back together. i put a catch can on each valve cover opening and a small filter on the openings that went back into the system. i did notice that when i plugged the hole on the passenger side of the intake manifold my idle dropped slightly. I did an engine swap last year and since then my idle seemed to be slightly high so with the hole plugged it is almost exactly at factory recommendations. should i plug it or put a filter on it to allow air in? sorry, just because i can do an engine swap does not mean i know what all those stupid hoses do. Are there any other hoses etc i can take off for performance? Inspection is not an issue. <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: yekrahs]
#885816
05/23/08 04:07 PM
Reconnect the tubes from the valve covers to the intake like they were from the factory. They are there for a reason, positive crankcase ventilation (PCV). Keep the catch cans in the lines if you want. And yes, there is a difference between ventilation and positive ventilation. The reason your idle changes is because you are creating a vac leak by disconnecting the hoses. Without PCV your engine can sludge up, big problem. Read here for more info: http://www.yotarepair.com/Sludge_Zone.html
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
[Re: mt_goat]
#885817
05/23/08 05:29 PM
what?? you mean i cannot get the extra 110 hp my truck needs by simply pulling a few hoses off.what if i pulled the hoses and jammed in some whip cream canisters as a nitrous system? (i think cheese whiz would lead to a lot more sludge don't you?) seriously though thanks for the info.i'll get it all back the way it was before i started messing with it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: yekrahs]
#885818
05/23/08 08:01 PM
what?? you mean i cannot get the extra 110 hp my truck needs by simply pulling a few hoses off... <img src="/forums/images/graemlins/cheers.gif" alt="" /> As surprizing as that may be LOL.
