Thinking of using SVO #885873 05/14/08 10:14 PM
Glock24 Offline OP
With the ever increasing fuel prices, it starts to make sense to use a mix of diesel/SVO, as you can buy it cheaper per liter than diesel fuel.
What is a safe diesel/SVO ratio to use? I don't have to worry about the fuel freezing, as the temp is never below 20?C at night, and ~35?C during the day.
'98 Galloper II Exceed 2.5TDI LWB 5sp Manual 5.29 Diffs
Re: Thinking of using SVO [Re: Glock24] #885874 05/15/08 05:56 AM
dylanb Offline
In my understanding, freezing of the SVO is not the real problem but gelling at lower temperatures is an issue. It has to be heated to maintain a liquid consistency. I'm not really too sure how it works with mixing fuels, but that is something to keep in mind as your fuel/SVO ratio goes up.
85 4x4 Pickup, 267K, 4d55 Conversion, Sway-A-Ways, Dual Batteries
Re: Thinking of using SVO [Re: dylanb] #885875 05/15/08 04:02 PM
drtydzl Offline
in know here in the united states the kit that i run in my 2001 powerstroke has a second tank that is heated in the bed that keeps the wvo OR svo at a constant 190 degrees this is the optimal running temperature this is achieved by using electric heaters in the tank or by using engine coolant to keep the oil at the temperatures needed to allow it to flow threw the fuel lines and then into the injectors with out clogging them also vegetable oil has a higher BTU rating than diesel to start with it is just the problem of keeping the oil in a liquid state but that is easy to remedy with heaters if you need any more info on this let me know
ALSO SVO = STRAIGHT VEGETABLE OIL WVO = WASTE VEGTABLE OIL
AS SUCH THERE IS NO DIESEL MIXED IN WITH IT YOU USE DIESEL TO START AND HEAT UP ENGINE THEN SWITCH TO SVO OR WVO AND 10-15 MIN BEFORE SHUT DOWN SWITCH BACK TO DIESEL
check out golden fuel systems good site plenty of info
1989 LWB 2.5L ITD 3" BODY LIFT AND 35 INCH BFG MT'S HOME MADE SNORKEL, AUTO METER PHANTOM SERIES BOOST, EGT, AND TRANS TEMP GAUGES,TURBO TIMER RETIRED
1992 PAJERO EXCEED LWB 3L ALL STOCK FOR NOW
CURRENTLY LOCATED IN JAPAN
Re: Thinking of using SVO [Re: drtydzl] #885876 05/15/08 06:07 PM
dylanb Offline
Right. I'm working on my own dual-tank system to start using WVO.
In response to your first question, I have found a couple of sources that say you can use up to 20% veg oil in your tank without having to worry about all the mods that the heating process entails.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6012 MB (Peak: 0.6577 MB) Data Comp: Off Server Time: 2026-07-09 15:41:36 UTC
