Trans problem
#886016
05/16/08 02:51 AM
I was wondering if anyone knew of a way to fix this or does it mean I need a new trans. When I shift to 5th gear it will go all the like it is supposed to but it will only slightly touch the gear and if I apply more gas is will start grinding. Also I have to hold it to keep it into the 5th gear position. Thanks Frankie
Re: Trans problem
[Re: Littlewhitepup]
#886017
05/21/08 03:50 AM
Help me getting worse gas mileage due to not being able to shift to fifth.
Re: Trans problem
#886018
05/22/08 04:51 AM
Check the shifter boot, pull it out and see if shifter stays put. Do you have a bodylift? May need to bend the shifter. If that is not the cure, the problem is mechanical. Try a tranny shop or search www.car-part.com for a replacement.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Trans problem
#886019
05/22/08 06:18 AM
Isuzu Moderator
Check the fluid levels (FIRST), then drain the fluids and tell us what you find.
Most likely, you are looking at a rebuild. 5th goes, 4th will follow and it will soon die.
Rebuilds are a pain. You will be hard pressed to find someone who has even seen the inside of an Isuzu transmission. One from a salvage yard is probably your best bet.
Good Luck, Michael
Re: Trans problem
[Re: mlclark]
#886020
06/07/08 03:38 AM
I have checked the boot. And yes I have a body lift. The boot is not holding it and the floor has been modifed so the shifter does not touch it. The fluild levels are good. I was planning on doing the trans from a salvage yard but there is only one I can find and Im not sure if it is good or bad or even man. I just called and they said they had one there. Is there any other year or truck/SUV that I can get it from that is the same? Thanks
Re: Trans problem
#886021
06/07/08 05:30 PM
Isuzu Moderator
If you have the 4cyl, the trans from a 1st gen Amigo or 2.3/2.6 Trooper will work as well.
Sean Strawmyer Back and ready to rock...... crawl. From Indiana or surrounding states and interested in wheelin'? Check out www.mwior.com
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6119 MB (Peak: 0.6817 MB) Data Comp: Off Server Time: 2026-05-29 22:26:50 UTCValid HTML 5 and Valid CSS
