why do I have engine codes but no check engine light?
#886923
05/22/08 03:46 AM
HI I jumped the diagnostic plug today and found codes: 24-25-26-31-51!!!
Why do the check engine never light up when I'm driving the truck.
I unplugged the battery for half hour to be sure to reset every thing. Still the same codes.
Help
the truck run not so bad (at least for 313k)
thanks
Re: why do I have engine codes but no check engine light?
[Re: guill]
#886924
05/22/08 03:50 AM
Only hard errors will keep the CEL on all the time. Many intermittent codes only flash the light (when the problem happens) and stores the code for later retrieval. But they should clear with the battery disconnected, maybe there is a problem with the ECU's trouble code memory.
[Re: 4Crawler]
#886925
05/23/08 04:00 AM
sorry. I forgot to tell that I ran the truck a bit after I pull the battery off. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
But I still didn't see any check engine light.
Is't more precise? <img src="/forums/images/graemlins/confused.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5950 MB (Peak: 0.6483 MB) Data Comp: Off Server Time: 2026-06-07 07:23:53 UTCValid HTML 5 and Valid CSS
